Results 1 to 10 of 10
    Feb 2020
    Default 2006 liberty SKIM pin code from hex dump.
    Hi, I have a hex dump and need the pin code from it. It's from an 06 Jeep Liberty. It came from a junkyard and I don't have the VIN from the vehicle it came from. I don't know what SKIM version this is. I'd like to know which bits are the pin, and it would be great if someone had the conversion table. Any information you can give me will be greatly appreciated. Thanks.
    Feb 2020
    Here's the actual hex dump.
    hello iprog+ is pin 0203
  4. The Following User Says Thank You to romucifer For This Useful Post:
    swappart (9th February, 2020)
    Feb 2020
    Thank you so much. I'd still like to learn more about this, since I will encounter others like this eventually. Do you know what SKIM version it is, and which bits in the dump are the actual pin?
    Quote Originally Posted by swappart View Post
    no sorry done with iprog script + jeep but with several dump and known pin code we must easily find the bytes of the pin code I don't think it's crypted I can be wrong the other members of the team will be able to confirm
    Feb 2020
    You helped me a lot already. I have been researching the iProg+ since you gave me the pin. I have 5 other modules. I could get the dumps from them tomorrow. If you're interested, maybe we could figure out which bytes are the pin, then over time maybe a decoder could be made.
    stoyanov's Avatar
    42 75 6C 67 61 72 69 61
    Quote Originally Posted by romucifer View Post
    If this pin not work try 4125.
  9. The Following User Says Thank You to stoyanov For This Useful Post:
  10. #8
    Quote Originally Posted by stoyanov View Post
    sorry script iprog don't work ?
    what use for this?
    thank
  11. #9
    Feb 2020
    I won't know if it works until next week. I'll definitely let you know.
  12. #10
    Feb 2020
    Removed because it was incorrect
  13. The Following 2 Users Say Thank You to swappart For This Useful Post:
    cheaper (19th January, 2024), Dmitryfree (13th October, 2021)
