the chip to be heated and the car does not start anymore what is the simplest solution to solve the problem?
If i understand you burn eeprom. If you read it first you can write dump in new eeprom and try. If you burn it before reading i thing best solution is virgin dump + new eeprom and coding with diagbox.
it seems to me that I did not connect to the pliers st01 the chip to be heated and makes smoke and does not function any more
the chip is no longer recognized by digiprog it tells me piece not found
do I need to change the chip? and I do a blank dump?
do you have a tool crack for digiprog please
sorry eČ tool crack for digiprog 3
If you destroy only the eeprom new eeprom + virgin dump is the best solution i think. Post bsi nr and what is the type of eeprom?? 95128? 24c128? And you can use edit function to not produced so many posts.
sorry yes you are right for the messages that I did not know, so I normally have the chip 24c128, with digiprog then I empty the chip? with FFF everywhere?
bsi 9664983080 peugeot 207 2008 yearon the other hand I am no longer the 24c128 chip I throw them is it serious?
FF is not ok for this type of bsi. I try to find virgin for you. You must find new 24c128 and pin for car. What is the ecu type?? Maybe i can calculate pin from ecu dump. And better use good quality programmer to do not more damage. In my country this type of bsi is very cheap so you can buy new-used and virgin them.
in my country (France) it is around 120 euros virgin ... bosh edc16c34 calculator. I start in the world of programming I do not have much material at my disposal.
So you think I'm buying the chip I can't send a blank dump?
what will i need chip 24c128, blank dump, lexia pp2000, xprog?
Some programmer xprog is ok, pp2000 and virgin dump. You need read ecu eeprom and post here to calculate pin. I give you pin and virgin dump. Telecoding bsi is your job. In my country (Poland) this type of bsi cost less then 5 euro. You can buy used bsi and virgin them.
very big work, as have said have learned from these errors, when you say ecu you only talk about bsi? as a Chinese eeproom programmer what advised me? and yes for 5 euros you have a good country here on ebay minimum 50 euros
