Fault code P 1570 after keys reprog and calculate with CGDI MB car start but cut , do i need to do a resync ?
Here the dump from EIS
P 1570 = immo problem
No pin in eis.
NB!!! Don't ask in PM old file password , Im not remember.
sorry mate i expressed my self poorly i need pin for keys program
From first post dump look like coctail and wrong size!
Load good eeprom dump from eis , for check calcalated key's.
Nicolas13007 (11th February, 2020)
This was read by CGDI programmer , it calculated a code with wich i programed the key , eis lock and unlock the steering lock , the car start and cut , do you think there is a immo problem or a sync problem ?
Look ecu autorization status.
Nicolas13007 (11th February, 2020), rafal (11th February, 2020)
Problem solved i made sync to the ecu and it works the code calculated by CGDI is good thank you for your help
