I have Scenic 1,6 16v with ac Sirius 32 readed by ktag (different than readed in flasher) Need help to immo off this file with good checksum I remember to cut 58 pin or unsolder resistor in ecu. Ecu numbers S110030030 A 7700114970 7700110471.
scenic sirius 32 with ac immo off ori.rar here you are cut pin or desoder resistor
how do you read sirius 32 with ktag ? i tried with boot mode but it says to me "communication error... control all connections". do you know something ??
Best regards .
Yes, my friend. I've seen your other post with nissan ecu. It works, but not by clicking the ems3132 ecu type. Try finding the right renault protocol in ktag for that ecu. Or, better, try Galletto. Or desolder, and write it into the socket with minipro tl866.
IPrometheus (28th September, 2020)
First.. Thank for your quick answer, its strange because in the ktag (clone) that i have. i have read a ems3132 with the protocol 336 (renault but with a different boot) but in the process conection that ktag shows its appears like a sirius 32 conection (the ecu that i'm trying to read and says communication error with the ecu ) ... i will try to see what else can be the problem ... and if it doesnt work i'll buy galleto maybe.
I am coming to you because I have 2 offs to do on sirius 32
one is in fact working perfectly on the other hand the other I cannot read in boot to the galletto are there several schemas for sirius 32?
which one you use thank you
Latest Ktag
3
Hi guys
Please help Immo off.
Megane 1 1.6 16v Automatic gearbox, with ac
Sirius 32 H
S110110004
8200055742
Dump attached
grant 1.rar here you are cut pin 58
Travisrenaultma (30th November, 2020)
Sorry vladanr but will not let me access grant 1.rar
grant 1.rar try again
thank you guys but i'm reading me
i made a nikel sirius 32n
and the other sirius 32 doesn't want to know anything
but I pence that the protocol is not the same because one with infineon microprocessor and the other siemens
if someone can read the Siemens microprocessor, I would like to use the method, thank you
