Results 1 to 8 of 8
    Jan 2020
    Default DELPHI RCD310 read eeprom issue
    I try read EEPROM 24cl32 in car radio Skoda swing, but without success. Carprog or RPI3 shows all 00. Someone has an idea why it doesn't work? The radio works normally. Thanks.
    May 2019
    Did you unsolder it or trying read on a board?
    Jan 2020
    I tried read on board.
    May 2019
    Will be simplest unsold an eeprom I think or unsold two resistors conected to 5,6 pins IC if you don't want unsold IC
  5. The Following User Says Thank You to tomaru For This Useful Post:
    Jirka02 (11th February, 2020)
    Jan 2020
    I'll try tomorrow
    Jan 2020
    I tried unsold IC , but it still not work! I think eeprom is death, because RPi3 not found on list of i2c-adress.
    Aug 2019
    Johannesburg RSA
    Here is a dump from a RCD310 Delpi. Eeprom is a 24C32. code for dump is 0700.
    ROM246.rar
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by Jirka02 View Post
    hy .you need thise toll
  10. The Following User Says Thank You to catalinosonesti For This Useful Post:
    Jirka02 (12th February, 2020)
