    Oct 2017
    Default vvdi bmw or autohexII or bmw explorer
    i am planing to make bmw keys.Which device is best between these 3 devices.
    Experienced Advice is highly appericiated.
    Thanks and reps.
    I have all of them .... and some more. Once one failed then another one covering. Which is the best? It depends what are you doing and what is the software version.
    The cheap onces will give you more troubles then those more expensive (for sure), however sometimes those expensive are unable to complete the job so you pull up those cheap china.
  3. The Following User Says Thank You to qwojtus For This Useful Post:
    Asifmehmmod1 (12th February, 2020)
    Dec 2016
    Quote Originally Posted by Asifmehmmod1 View Post
    Thanks and reps.
    Only for BMW keys business ? it's not an OBD2 job for all cars after 2008 updated !
    autohexII or bmw explorer are too expensive for only made keys
  5. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
  6. #4
    ghostrider72's Avatar
    Jul 2012
    UK
    I have VVDI and AH. You simply cannot compare them. Completely different tools
    Dont take me wrong, vvdi is still decent tool if you do plenty of back up on bmw.
    AH works fine for me. Support also great. If you in doubt they explain or fix it within a minutes. Had to use support once and can’t fault them.
    Basically you get what you pay for. You cant just but Fiat and expect to have Mercedes quality .
  7. The Following User Says Thank You to ghostrider72 For This Useful Post:
  8. #5
    ray-ray's Avatar
    I also have them all but the best is Explorer by far.. ( for the smart person ) with very fast pc
    Autohex ( for the not so smart person ) Ok PC will do.VVDI ( for the person is on a budget) acer pc
    And don’t forget your motronics battery maintainer.
  9. The Following User Says Thank You to ray-ray For This Useful Post:
  10. #6
    Oct 2017
    its good to buy autohexII with hex prog for decent amount.
    VVdi bmw is still in development for advance features.
    Bmw explorer is too expensive for me.
    Thanks for all of your Support.
