Gs300 ecu and immo smartkey files
Results 1 to 4 of 4
    Feb 2020
    Downloads
    Uploads
    Default Gs300 ecu and immo smartkey files
    Hi could someone help Me out with gs300 2006 ecu and immo files to add and delete keys in diagnostics? Friends gs300 is not starting and showing immo fault. He changed the ecu module and seems that we need dump files to get it running again... Could someone help us with files we really need to get that gs running, as it sat in the dealershio for 3 weeks and evenetually they told that there is nothing they can do to get it running.
    Jan 2017
    USA ����
    82
    Downloads
    Uploads
    Quote Originally Posted by Rickuuu View Post
    immo fault is not a trouble code
    nor does it give us any idea what the problem is
    be more specific
    or get no help
    The thanks button is HERE looks like this --->>> THANKS
    Feb 2020
    Downloads
    Uploads
    Hi. Seems that immo is not communicating with the new ecu. If you go to car and try to turn it on nothing happens. Ecu obd reset has been tried and it did not work. It wont even turn on the ignition and light on button stays orange.
    ray-ray's Avatar
    Nov 2009
    36
    Downloads
    6
    Uploads
    AAB proxy (ECU, ID Box, and smartbox) need to be virgin and sinq. Then you need tis to wake up the button and go into program proxy.
