Results 1 to 7 of 7
    Oct 2015
    Italy
    Default Remove speed limit Mitsubishi
    Hello to all,
    I have a problem, I have to remove the speed limiter from a mitsubishi canter with bosch 0281020063 control unit. I can't find the block. can you help me?
    Oct 2015
    Italy
    is it possible that the limitation is in the eeprom?
    Sep 2018
    please send ori file.
    Oct 2015
    Italy
    the "ori_flash_tunning" file have dpf/egr and tunning modify.
    Oct 2015
    Italy
    This Mitsubishi have speed limit at 87 Km/h because have a Tachigraph. I need remove this limitation
    Jun 2018
    Bulgariq
    Quote Originally Posted by BRUNOXXX View Post
    test and report
    pass-PM
    edit file (flash.ori)
  7. The Following 2 Users Say Thank You to naskochipa For This Useful Post:
    BRUNOXXX (12th February, 2020), chafik4051 (12th February, 2020)
  8. #7
    Oct 2015
    Italy
    Sorry for delay, i've tested your file but a same limitation.
