Results 1 to 6 of 6
    Nov 2009
    EUROPE
    Default Citroen ds5 transmission nightmare
    Hello everyone i have this devil car to my store with transmission fault code p1755.fault is on when i will put the lever to A.or R.car is not moving.i tried to do basic settings with x431.the procedure started ok.first the values has been erased and program said to hit ok to go to another stage of basic setting.hit the ok and the gearbox was doing kicking noises.when stopped said switch off and on to go after.i did that and said procedure has been failed.then i switched of and on and i am having new code now immediately p1733.any help please?also i have put out the clutch for inspection but seems fine is luk clutch kit.
    Nov 2009
    EUROPE
    This is the type from transmission
    Meat-Head's Avatar
    No idea read this see if makes it worse
    ADVERTISEMENTS
    https://car-recalls.eu/recall/citroen-ds5-2016-2/
    Apr 2013
    For P1755:
    - If the clutch learning fails: replace the clutch and the clutch release bearing
    - If the learning is successful: Replace the MCP actuator kit (complete MCP controlling device without the clutch release bearing).
    For P1733:
    is a problem with the position sensor or the small harness on the MCP actuator.
  5. The Following User Says Thank You to Tachodiag For This Useful Post:
    kospoz (12th February, 2020)
  6. #5
    Nov 2009
    EUROPE
    Quote Originally Posted by Tachodiag View Post
    For P1755:
    For P1733:
    The basic setting was aborted after 2 stage which was gear selector then the 3 stage probably is for clutch learning.
    The position sensor is inside of mcp or is a part that can be changed?
  7. #6
    Apr 2013
    spare part. pay attention , there are 2 identical sensors . if you dont know which one is the position sensor replace both.
