Results 1 to 5 of 5
    Default Renault Clio 2007 replacement / clone such
    Hello all I’m in need of some help with a replacement Uch n85 on a Renault Renault Clio Sport 2007. I have got a replacement Uch with the same numbers. What is needed in being able to clone or transfer data between the two? I have ordered a Renolink Red obd SX cable as I see this has many functions for this , But unfortunately it’s stuck in China due to virus! Can the eprom just be swaped?
    Aug 2011
    swap eeprom from ori uch to second. if not you will need pin security and 2 new key for programing
    Ok perfect thank you so all keys remote will work yes? Also do you know what eprom is inside?
    Mar 2018
    France
    hi,
    it's not an eeprom inside, it's a mcu MC9S12DG256
  5. The Following User Says Thank You to mewan For This Useful Post:
    Galee (14th February, 2020)
    Feb 2020
    Belarus
    Hey. I did the replacement of UCH with the first generation megane (2002). Rearranged the processor and everything works.
  7. The Following 2 Users Say Thank You to Serg79 For This Useful Post:
    BusCan (30th May, 2023), Galee (15th February, 2020)
