Results 1 to 8 of 8
    Apr 2010
    Default MEVD 17.2 ISN change
    Can anyone change the ISN in the MEVD 17.2 ?
    Im thinking to read the valid ISN from CAS and then insert that to new donor DME
    nici's Avatar
    Apr 2017
    Poland
    No, u have to read isn from DME and inset to CAS. This is correct way.
    ECU REPAIR , cloning ECU
    Chip Tuning dumps ECU - ORI MOD, DPF FAP
    Flashing ECU , diagnostic etc.
    ! CODING // UPDATE // RETROFIT BMW / MINI !
  3. The Following User Says Thank You to nici For This Useful Post:
    Col19 (30th November, 2021)
    Apr 2010
    Quote Originally Posted by nici View Post
    If I do this way then I will lock out the 8hp19 trasmission security since the tranny shares the same ISN. I believe that I need to just change the ISN in the donor DME
    Apr 2019
    I think mean to read ISN from the old non working DME and write it to the new one
    I am a newbie to the BMW security stuff correct me if I am wrong please.
    Sent from my ONEPLUS A3003 using Tapatalk
  6. #5
    Apr 2010
    You can read ISN from the ol dmodule if the module communicates or you can read the same ISN from CAS module. it does not matter.
  7. #6
    bearheroes's Avatar
    Dec 2011
    Post isn and ecu eeprom
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  8. #7
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by astrofil View Post
    I did that with a mevd17.2.3 a couple months ago. Read from the original, wrote to the donor. Did it with Autohex but also tried CGDI, which had no problems with it. If I remember correctly, a 2018 Mini, according to my bud who brought me the ECUs.
    <---- Coin of the Realm.
  9. The Following User Says Thank You to droidwayne65 For This Useful Post:
  10. #8
    Apr 2010
    Here are the P Flash and D flash of the new donor DME
    The new ISN below needs to be written in
    If You could also adjust the VIN that would be awesome.
    I have sent the VIN over the PS
    ISN F9 31 OB 7E BB 52 81 2A 68 3C 02 82 DE 31 57 C2
  11. The Following User Says Thank You to astrofil For This Useful Post:
    polany (15th October, 2021)
