Ford Focus
Results 1 to 8 of 8
Thread: Ford Focus
    Croatia
    1,425
    Default Ford Focus
    Hello
    Need help to clear airbag from Ford Focus 2005.year.
    Ecu is 4M5T 14B056 BF - 0 285 001 552
    Thank you ...
    superjet's Avatar
    Aug 2018
    181
    Here you are.
  3. The Following User Says Thank You to superjet For This Useful Post:
    Mezz_cro (14th February, 2020)
    Croatia
    1,425
    Quote Originally Posted by superjet View Post
    Here you are.
    Not work,after i put your file too many DTC, B1231, B1342.....etc.
    Any other solution ?
    Thank you ...
    superjet's Avatar
    Aug 2018
    181
    Try this........
  6. The Following User Says Thank You to superjet For This Useful Post:
    robert1232's Avatar
    Dec 2010
    Where They Need Me
    438
    Default here is your file
    thanks+reputation=pass
    raport
    Quote Originally Posted by Mezz_cro View Post
    Hello
    Thank you ...
    PRESS THANK YOU AND REPUTATIONS.
    DON'T PRESS, I WILL NOT HELP NEXT TIME
  8. The Following User Says Thank You to robert1232 For This Useful Post:
  9. #6
    Croatia
    1,425
    Try this........
    Not work....
    B1231, B1342 still....
    other solution ?
  10. #7
    Croatia
    1,425
    Quote Originally Posted by robert1232 View Post
    raport
    Works...
    Thank you ...
  11. The Following User Says Thank You to Mezz_cro For This Useful Post:
    robert1232 (14th February, 2020)
  12. #8
    robert1232's Avatar
    Dec 2010
    Where They Need Me
    438
    thanks for raport
