Results 1 to 7 of 7
    Jul 2015
    Default ERASE ALL DTC TABLE FROM 206 HDI EDC16C34 0281012528
    Hi Guys!
    Can anyone help me? I have a file modifiy to idle at 1800rpm and with maximun torque at these rpm. I use the engine like a AC Generator in a truck.
    But after aproximately 10 minutes of use the engine imits to 900rpm and some dtcs are stored.
    COuld anyone erase ALL DTC table????
    Best regards
    Meat-Head's Avatar
    Thats well cool.
    can you fool it into having a speed pulse.
    if faults code P0500 then yeah needs some kind of speed pulse.
    if you have 240 vac then could you somehow get a mains synrious motor driving a speed pulse generator
    more intrested in photos of setup
    Jul 2015
    DTC are these:
    Really i dont unserstand properly what you mean with "having a speed pulse". Photas will be requested to my customer and link hear as soon as possible. Initially the truck and generator was into my garage but now the track is into my customer garages and only works in the ECU.
    In fact the track never was in my garage , only the assembly engine+generator. I chipped the ecu with help of this forum and tested that genereator generate 220v 50 HZ and all seems fine. But now my custumer detect after use it that limit 10 minuts after start engine.
    I try to add photos but if anybody has any idea??? THe dtc related to the throttle pedal were solved, was a bad connection but still limitng after 10min.
    I wish to erase all dtc and test.
    best regards
    Aug 2008
    cant see the dtc's the pic isnt good enough
    Jul 2015
    P0098
    P0693
    P0215
    U0121 (RELATED CAN msg missng)
    U1118 (RELATED CAN msg missng)
    Aug 2008
    would also help to post the file you need the dtc's removing from
    Jun 2020
    Default Merci
    Merci pour l'information 👍🏻
