Help with flash programming 27C210A
Results 1 to 11 of 11
    Jul 2018
    120
    Downloads
    38
    Uploads
    Default Help with flash programming 27C210A
    Hello my friends, I need flash programming
    27C210A , but I cannot and always appears this mistake. Please help to solve this problem and what is the best programmer to deal with this type of flash
    avital's Avatar
    May 2010
    ARCADE GAME
    29
    Downloads
    98
    Uploads
    27C210A is not FLASH of course - it is Erasable PROM , before try repair something in customer car , I study some informacion about parts (PDF - IC) of which the module is built , I recommend this action to you too.
    CALCULATOR for IMMO VAG WFS5/WFS4 - ECU EDC17/MED17/MED9.X/SIMOS8.41/PCR2.1/CCM/BCM2/ELV - full edit/copy data , check and change POWER CLASS/MARKEN CLASS, export and import security block (immo data). Production and development professional immobilizer/ESL/ELV/SRS emulators.
  3. The Following User Says Thank You to avital For This Useful Post:
    narkeleptk (15th February, 2020)
    Jul 2018
    120
    Downloads
    38
    Uploads
    Thank you. This is not for the customer. It is mine. Second, what is the best programmer for this EEPROM?
    Cardiag.ru's Avatar
    Apr 2010
    Russia
    8
    Downloads
    Uploads
    That IC is UV eraseble, and before write it you need ERASE
  6. The Following User Says Thank You to Cardiag.ru For This Useful Post:
    mnem (16th February, 2020)
  7. #5
    avital's Avatar
    May 2010
    ARCADE GAME
    29
    Downloads
    98
    Uploads
    unfortunately I don't know if the author of the post understands what UV means
    Wysłane z iPhone za pomocą Tapatalk
  8. #6
    Oct 2018
    egypt
    47
    Downloads
    35
    Uploads
    It's not that way as best programmer for this ... but try to know differences between Eeprom (electrically erasable)and Eprom(erasable) ... how to get them blank ??
    wbr.
  9. The Following User Says Thank You to hesham10 For This Useful Post:
  10. #7
    Aug 2008
    60
    Downloads
    48
    Uploads
    uv light or leave in sunshine for a very long time
    oh and remove sticker over glass before then after reprogramming make sure you recover glass
    but also as said above do some homework before jumping in head first
  11. The Following User Says Thank You to tango For This Useful Post:
  12. #8
    Jul 2018
    120
    Downloads
    38
    Uploads
    tango Thank you very much for this useful information
  13. #9
    Jul 2018
    120
    Downloads
    38
    Uploads
    thank you very much hesham10
  14. #10
    Jul 2018
    120
    Downloads
    38
    Uploads
    thank you very much Cardiaq.ru
  15. #11
    Jul 2018
    120
    Downloads
    38
    Uploads
    Thank you all I have been studying for a topic and problem solving https://www.youtube.com/watch?v=EghQ7YXIhm8
