Results 1 to 8 of 8
    Nov 2016
    Default Problem with clutch a3 8p
    Hello everyone, maybe someone will help me here, for which I would be grateful. The problem concerns my Audi a3 8p 2.0 tfsi Quattro, the problem is that it does not always bounce back the clutch, I have already replaced 2x complete clutch with dual mass, 3x clutch pumps and spring pedal clutch, and yet the problem is still the same, maybe someone had a similar symptom? I have no idea what the reason may be ... I will be grateful for any suggestions. Regards.
    Mooti's Avatar
    Nov 2018
    Buddy, can you tell me if the sleeve leading from the clutch is ok?
    And is the brake fluid clean?
    Nov 2016
    The fluid is new, the bushing did not seem loose, the problem is that the pressure seemed to disappear for a while and there was no rebound of the coupled pedal.
    Jul 2017
    the system is aerated, check the connections
    Nov 2016
    There is no air in the system, I checked many times.
    Mooti's Avatar
    Nov 2018
    And there are no different heights of the dual mass wheel?
    Nov 2016
    Problem solved.
    Mooti's Avatar
    Nov 2018
    How did you solve the problem?
