Results 1 to 13 of 13
    Aug 2019
    Default BMW Start Button stop from shutting off Ignition while writing OBD.
    Hey Guys,
    in the past i had issues with BMW Start Button Ignitions. Because while writing and causing problems not sure if the Ignition kept shutting off because the Dashlight stayed on but writing failed.
    I tried the 2 fast press of the button method.
    I tried holding 4 sec or 10 sec method.
    Is there something im missing ?
    Thanks in advance.
    jurebv's Avatar
    Dec 2017
    Croatia
    seat belt?
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
    chrisimerk's Avatar
    Dec 2018
    England
    You have to press start button without pressing clutch pedal or brake pedal and cluster show you all the lights but car doesn't start never press brake pedal or clutch while pressing start button as it will auto switch off during write or read hope this helps
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
    Aug 2019
    Quote Originally Posted by chrisimerk View Post
    I did not press Brake Pedal or Clutch while klicking the Start Stop buttons at the beginning.
    Aug 2019
    ANY TIPS ?
    jurebv's Avatar
    Dec 2017
    Croatia
    seat belt on
    Aug 2015
    Germany
    e-series bmw or wich one? if so than try unplug ibs sensor
    Aug 2019
    E60/61 had this problem twice in the past ? Does anybody have some other tips?
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Yes, I have few...
    Always connect stabilised power supply, min. 100 A at 14 volts...
    Open the driver door and fasten driver seat belt.
    Never ever had any problems with any BMW!
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
  10. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    caja88 (20th February, 2020), jenny123 (22nd February, 2020)
  11. #10
    May 2017
    Newer BMWs sometimes .... need press quickly 3 times start button in row to enter service mode. Thats all. No shutting down ecu...
  12. #11
    Aug 2019
    Any other ideas? Or somebody that experienced something like that and knows for sure ?
  13. #12
    Aug 2019
    Anyone with some ideas ?
  14. #13
    Feb 2020
    Germany
    Never had Problem with this ecu
    I do like Kess say an 80A Power supply
