Results 1 to 10 of 10
    Mar 2017
    Colombia
    Default Clone UCH MEGANE/SCANNEC II
    Hello DK Gentlemen, have a Happy Weekend.
    I would like to Ask and solve Problem with a Megane / Scenic II 2006 car.
    I have an original Daņana, even if the car still starts.
    I want to exchange UCH for a donor.
    Could anyone help me to do this job with modified DUMP?
    here My 2 files, Original 2key and Donor (Virgin).
    Thank you very much for your attention, I hope to resolve. :-)
    WINNER THE LOSER
    rafal's Avatar
    Jul 2010
    UK - PL
    hi
    why not just copy ori file to donor?
    pin: 08 F9 AB 7A D8 25
    isk: 4C 33 A4 FA B6 21
    or by obd:
    https://www.digital-kaos.co.uk/forum...H-virgin/page2
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following 2 Users Say Thank You to rafal For This Useful Post:
    Adam871 (17th February, 2020), Louislesinge (16th February, 2020)
    Dec 2018
    there is no need to read the processor, there are cheap devices that do obd2
    Mar 2017
    Colombia
    Quote Originally Posted by rafal View Post
    hi
    or by obd:
    I already tried to copy the Donor, but it didn't work.
    WINNER THE LOSER
  6. #5
    Mar 2017
    Colombia
    Quote Originally Posted by Catalizator View Post
    I have Renolink. But I don't know the process to be done, could you turn me on?
    WINNER THE LOSER
  7. #6
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by automotrizVIP View Post
    so do this job by obd....................
    need help
    who will help?
  8. #7
    Dec 2018
    нужно прочитать и сохранить пин-код и иск. затем подключите другую уч, чтобы сделать девственную команду чистой. Ренолик прост в этой работе, все понятно
    do not give the virgin command unless you have read and saved pin and isk from the original uch
  9. #8
    Mar 2017
    Colombia
    ok...
    I have read, UCH Original I have ISN + PIN.
    virginize Uch Donor.
    But I always have "this command is not possible"...
    I put key New and used. Same mistake....
    Any suggestions?
    WINNER THE LOSER
  10. #9
    Dec 2018
    turn on virgin uch and try to educate
  11. #10
    Aug 2020
    Program the uch you have all correct numbers
