Results 16 to 30 of 45
  1. #16
    mrjay88's Avatar
    Apr 2018
    UK
    ive tried to write my original file back to the car it errors on security acsess
  2. #17
    chrisimerk's Avatar
    Dec 2018
    England
    looks like your going to have to bdm it and write ori there was nothing wrong with the file i provided as i have used it on many ppds with the same modifications so something not quite right with tool on this occasion maybe mpps messed up checksum or voltage drop hard to say mate
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  3. #18
    mrjay88's Avatar
    Apr 2018
    UK
    i dont have a bdm mate i wouldnt even know where to start is my car dead
  4. #19
    chrisimerk's Avatar
    Dec 2018
    England
    Only way to recover ecu is to bdm its locked ecu aka bricked these are the risks when messing with ecu especially using dated tools v13 has no recovery option if you was using kess v2 or v18 you might have been able to recover it v13 is not stable maybe it worked in the past but there are always risks anything can go wrong.
    if you dont know what your doing then look about for someone in your area who can bdm and write the new file a provided thats all i can do from here mate
    (DEMON DEVELOPMENT)
  5. #20
    mrjay88's Avatar
    Apr 2018
    UK
    so if i buy a mpps v18 or kess v2 can i recover my ecu via the odb port
  6. #21
    chrisimerk's Avatar
    Dec 2018
    England
    possibly as the latest kess v2 clone has a recovery option and is way more stable and also v18 can also recover but i would use that money to pay someone to bdm it as i cant guarantee that kess and v18 will be able to recover it through obd
    (DEMON DEVELOPMENT)
  7. #22
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    try to flash this file in recovery by mpps and put battery charger during flashing and report here
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  8. #23
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by AVDigitale View Post
    my mpps v13 does have recovery mode but now even in recovery mode all i get is (required time delay not expired followed by invalid key) on mpps
  9. #24
    AVDigitale's Avatar
    Apr 2017
    you have write check and you have speed up and make slow speed recovery you will see
    put my file and car will start
    File Service
  10. #25
    mrjay88's Avatar
    Apr 2018
    UK
    so basically set my mpps to recovery mode and write your file to my car and it will start
  11. #26
    AVDigitale's Avatar
    Apr 2017
    yes try put good battery charger 14v
    File Service
  12. #27
    mrjay88's Avatar
    Apr 2018
    UK
    your flash file is 03G906018EM my original file is 03G906018DF does this matter
  13. #28
    AVDigitale's Avatar
    Apr 2017
    flash no worry is ori file for your car
    File Service
  14. #29
    chrisimerk's Avatar
    Dec 2018
    England
    If it takes AVDs file as that is the original that has not been messed with it should take it and recover then flash the new file that I posted
    (DEMON DEVELOPMENT)
  15. #30
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by chrisimerk View Post
    ok i will try tomorrow as its late now ive been reading up that when mpps says (required time delay not expired followed by invalid key) you have to wait 30 minutes with the ignition on because its locked me out is this true
