Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
  1. #31
    chrisimerk's Avatar
    Dec 2018
    England
    Yes it true another thing v13 does its the clone software that's the issue but anyway leave the ignition on for a full 10/30 minutes to let the timer expire then try again
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  2. #32
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by chrisimerk View Post
    ok so leave the ignition on for 30 minutes with a good battery charger connected do i need the mpps cable plugged in the whole time with the software open or leave the mpps unplugged then plug it after 30 minutes with the ignition still on or turn the ignition off after 30 mins then plug it in then flash sorry for my stupidity just want to be 100% also if i was to buy a mpps v16 or v18 will i still have this timer issue or will it bypass it. and am right in saying this is neither of our fault its just a crap cable
  3. #33
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by mrjay88 View Post
    i tried to recover my ecu today and its a big no i waited 30 mins all i get is invalid key wont take any maps and keeps saying immo active and engine workshop the car will start then cut out after 5 or so seconds
  4. #34
    chrisimerk's Avatar
    Dec 2018
    England
    wait 30mins with ignition on with software open
    (DEMON DEVELOPMENT)
  5. #35
    mrjay88's Avatar
    Apr 2018
    UK
    i tried that mpps says invalid key
  6. #36
    chrisimerk's Avatar
    Dec 2018
    England
    yeah your tool is not very good if all your wanting to do is that car or your own cars then purchase mpps v16 its cheap but still better and more stable then v13
    (DEMON DEVELOPMENT)
  7. #37
    mrjay88's Avatar
    Apr 2018
    UK
    would a kess v2 master clone be a better option than any mpps if so ill go buy one and will the kess fix my problem
  8. #38
    Oct 2019
    Italia
    hello I did not put all the discussion, in the end you solved?
  9. #39
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by Fronzies View Post
    sorry no ive not solved my problem the engine start is blocked by the immobilzer since the remap
  10. #40
    Oct 2019
    Italia
    hello first what instrument did you read and write with? now does ecu id you?what ecu mounts?disassemble laws in bdm? if you do not have to identify in bdm, try manually with the right protocol. if you can read the original mail flash and flash read in bdm
  11. #41
    Myjector's Avatar
    Dec 2017
    Take your ecu to an professional that can flash a FRF our buy a ktag clone and read the bdm file and post it here.
    AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
    FULL SWIFTEC AND EVC RESELLER
    FILE SERVICE FROM 8AM - 9PM 7/7
    BAPRO 4WD DYNO
  12. #42
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by Myjector View Post
    ive orded a mpps v18 tricore multiboot hopefully that will recover it and im able to bench flash with that whats the best bench power supply and what voltage and amps do you guys run or does it depend on the ecu
  13. #43
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    your ecu need BDM not tricore
    KTAG is good for BDM or FGTech Galletto
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  14. #44
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by AVDigitale View Post
    right ive been doing a lot of reading and research from what i understand the optican 201 is the bdm adaptor i need for my ppd but what box is compatible with the optican 201 i.e ktag bdm100 etc.. and what bench power supply is good for this i understand the ecu needs 13 volts but how many amps
  15. #45
    Apr 2021
    please could i get this file also. im new to mapping just need it for my car. my map worked for about a month and car not run properly sice. every mechanic who looked said its the map
