Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    mrjay88's Avatar
    Apr 2018
    UK
    Wink Golf MK5 GT Diesel stage 1 needed please
    hi i am in need of stage 1 remap more power for my car please can some one tune my file to atleast 205bhp the stock power is 170bhp i have a ramair cold air intake egr delete dpf delete and a 3" milltek cat back exhaust and would like take full advantage of my upgrades it would be very much appreciated thanks
    ECU Type: PPD
    Code Version: SN100L8000000
    Part Number: 03G906018DF
    Info String: R4 2.0l PPD1.2
    Read using mpps
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by mrjay88 View Post
    ECU Type: PPD
    Read using mpps
    here you go mate your lucky i did one last week with same mods made 208bhp and 430nm on dyno
    pass in pm
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  3. The Following 3 Users Say Thank You to chrisimerk For This Useful Post:
    AngelOfMercy (18th April, 2021), Ilyll123 (7th June, 2021), mrjay88 (16th February, 2020)
    mrjay88's Avatar
    Apr 2018
    UK
    Quote Originally Posted by chrisimerk View Post
    pass in pm
    Thank you mate your a legend really really appreciate cheers
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    this car never can go to 208 hp in stg1
    this engine lost power in stock 150 152 hp max dyno tested many times
    190 hp in stage1 you will be happy
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    chrisimerk's Avatar
    Dec 2018
    England
    thats why the file i have provided is not a stage1 tune my friend these can easily get 200+ with the modifications he has listed tested also many times
    (DEMON DEVELOPMENT)
    mrjay88's Avatar
    Apr 2018
    UK
    how u doing pal ive mapped my car using the supplied map u gave me now my car wont start it says immobiliser active starts then cuts out
    chrisimerk's Avatar
    Dec 2018
    England
    choose recovery option and flash ori back on obviously something went wrong hows the voltage did you have a stable source of power to the battery
    also if your fans are running make sure to unplug them its just under the front bumper
    (DEMON DEVELOPMENT)
    mrjay88's Avatar
    Apr 2018
    UK
    My mpps cable doesnt have recovery mode and yes steady power to the battery
  10. #9
    chrisimerk's Avatar
    Dec 2018
    England
    in the right hand corner it will say recovery? will it ID and communicate?
    (DEMON DEVELOPMENT)
  11. #10
    mrjay88's Avatar
    Apr 2018
    UK
    No mate deffo no recovery its mpps 13.02 if that helps
  12. #11
    chrisimerk's Avatar
    Dec 2018
    England
    for starters i would not have used mpps with this ecu especially v13 its not stable if i new you had used v13 i would have said use kessv2 for this ecu and dont risk writing the file with mpps if it was v18 then ok that has no problems was your voltage above 13v?
    (DEMON DEVELOPMENT)
  13. #12
    mrjay88's Avatar
    Apr 2018
    UK
    yes it was just above 13v i have used this cable many times on my car i did the egr and dpf delete my self with the same cable oh and i added a popcorn limiter in the past work fine no problem
  14. #13
    chrisimerk's Avatar
    Dec 2018
    England
    can you communicate with it? will it let you write ori?
    (DEMON DEVELOPMENT)
  15. #14
    mrjay88's Avatar
    Apr 2018
    UK
    yes i can. ive noticed though the map u sent has dt at the end mine is df
  16. #15
    chrisimerk's Avatar
    Dec 2018
    England
    right thats good write this file should have no problems with it mate
    same pass
    (DEMON DEVELOPMENT)
  17. The Following User Says Thank You to chrisimerk For This Useful Post:
