Results 1 to 4 of 4
    Jan 2019
    Default HELP Kess v2,47 ,,ERROR SECURITY CODE NOTE READY''
    hello, yesterday i was able to read the computer on vw craffter edc16-109ps i removed the egr and dpf from the car with DPF remover and EGR remover, i successfully saved the file the car started moving without a problem but today i wanted to save another file but it gives me an error.
    tried 3 variants
    with contact waiting 30.40 min,
    2 variant with min speed change and max
    3 variant with external power supply
    gives a security code not ready error ........
    May 2018
    Read BDM
    Sometimes crafter have any problems via OBD.
    Wysłane z mojego SM-N970F przy użyciu Tapatalka
    Feb 2020
    ZIMBABWE
    im also failing to read denso 175822-799 on KTAG 7.020 any1 tried that hino ecu
    says ecu not identified
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by phaka View Post
    check connections again, if ok...(?)
    then you have a LQ clone...
