Results 1 to 9 of 9
    Feb 2020
    Default EDC16C34/2.20 1037399617 g8db Ford Focus Kess v2
    Good evening everyone, kindly I need help, I have a Ford focus 1.6 tdci of 2009 engine code g8db, I own the kess v2 clone where, however, in the list there is the abbreviation g8da not g8db, I was able to read the file through kess anyway, the control unit is identified as EDC16C34 / 2.20 the software number is: 1037399617 what I ask is you can write this control unit with the kess v2 clone, can you please help me?
    Oct 2018
    Earth
    Hello, the most secure way it's with BDM, if your kess is good eu clone, i think will do that ECU but need to make it exactly the way KESS V2 say it... after flash wait 3 min and i forgot other special requirements...
    stanislav georgiev's Avatar
    Oct 2014
    България
    Once you've read it, you should be able to write it down.
    Feb 2020
    Good evening thank you for the answers, my kess v2 is version 2.47 it was bought recently on amazon if you want I still have the link with the specifications, however it is the one with the red pcb, if I proceed with the writing waiting 3 minutes I run the risk of blocking the control unit? In the meantime, thank you guys
    Feb 2020
    Sorry I still forgot, the machine has a g8db engine code which is not present in my kess, in my kess it has the g8da can I write the file possibly selecting g8da?
    Oct 2018
    Earth
    As stanislav georgiev says, if you read it with the tool, it's must and write it, the 3 mins waiting after flash is for injector calibration.. Everytime it have risk when you flash ecu...
    Oct 2019
    Italia
    hello, with a good kess 2.47 you can write it and read it almost "safely". I on an ecu focus edc16 I have not had the opportunity to read it in obd.
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    first try if you can read is OK,if during reading stopping in 35-40% then you need BDM read/write
    BR
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Feb 2020
    Hi guys, thank you all for the answers
