Results 1 to 11 of 11
    Jan 2020
    Default Extracting eeprom
    Hello. Maybe someone could help me with what tools should I get from extracting eemprom from car radios? Saw many cheap tools on ebay and aliexpress but I have no idea what to buy. Thank You.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by sekb View Post
    extracting...?
    you mean read/write...?
    if yes, TL866, xprog, orange5, but much more others...
    if by clip or by desoldering...
  3. The Following User Says Thank You to figani For This Useful Post:
    zyldelfer (5th June, 2020)
    Jan 2020
    Quote Originally Posted by figani View Post
    extracting...?
    I would like to desolder chip and then extract information from it, but not sure about the tools to extract it.
    Mar 2019
    Earth
    Put a little flux on the surface of pads of eeprom.Then use the hotairgun 5-6 cm of the eeprom (temp 300-350 degrees) and then with a tweezer grab the eprom gently ,not to hard because you can easily rip the pcb traces.Afterwards with some solderwek remove the old solder of the pcb,put some flux and solder back your eeprom .It comes very handy and easy after a few tries.Good luck
    narkeleptk's Avatar
    May 2017
    USA
    Its pretty simple. You remove the chip, place it on adapter or socket and use a proper eeprom programmer to read it. I prefer tl866 or orange 5 for eeproms personally but there are many eeprom programmers available for whats usually found inside radio's.
    Mar 2016
    Portugal
    280 deg is hot enough to remove the chip with a hot air gun, 350 deg will fry the chip, happened to me only once because I failed to look up the temperature that the chip can with stand
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by CasaEd View Post
    280c? that is pretty low for most stuff unless its lead solder. I keep my hot air around 375c and adjust distance depending on what I need to remove. Never cooked anything.
    Mar 2019
    Earth
    i work everyday with eeproms and mcus ,my soldering station is set to 350 degrees.Depends on my hand skills i guess
  10. #9
    veneto
    wet the feet with iron solder using low melting tin (e.g. quick alloy) and then you can remove the component even at 250 degrees with your hot air station .
  11. The Following User Says Thank You to orx For This Useful Post:
    fuzz1 (9th April, 2020)
  12. #10
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by orx View Post
    Seems you have some experience. Any tip for soldering it back on?
  13. #11
    veneto
    Smile
    SOrry for late answer ... anyway the type of welding technique varies from the type of component, DIP (common eeprom) QFP and BGA. For the eeprom i use wet the prints with a bit of common tin paste or wire 60/40, no low fusion tin because it tends to crystallize and to crack on solder joint. Then with the soldering iron with a 0.2 mm tip (I recommend the copper tips) I help myself with the tweezers and I begin to go over the feet again. You can also use the hot air by shielding the nearby components with Kapton tape, air speed. medium and rotation of the handpiece so as not to concentrate the air on a single point. For QFP components the same story applies while for BGA it requires experience and a lot of pages...
  14. The Following User Says Thank You to orx For This Useful Post:
    fuzz1 (5th November, 2021)
