Results 1 to 2 of 2
    Sep 2018
    Default Fiat Ducato 3.0 EDC17CP52 DPF remove and dtc
    hello, could someone make dpf off and remove DTC P0131 P0132 P2454 in that file?
    CAR: Fiat Ducato
    Engine: 3.0 180HP
    ECU: EDC17CP52 HW 0281030431 SW 1037529156
    DTC: P0131 P0132 P2454
    thank you
    May 2018
    Probably you have also problem with lambda and differential pressure sensor.
    Maybe it is worth replacing the lambde and the differential pressure sensor?
