Results 1 to 3 of 3
    Feb 2020
    Default Immo off МSА11 4A0907401P 0 281 001 320/321
    Hi I have a problem with immo is a car start with 3 times.
    I want to disable the immo in the ECU there are 2 eproms. I do not know which one to read right (1pc) (or 2 pc to read) https://ibb.co/K95mbMB
    There is a program Immo Servis Tool v1.2 I will try to disable.
    The problem in immo for a long time and I read various forums where they indicated that you need to lock on the mass of the wire (either on the ECU or in the immobox), I can not find this topic now.
    You read in the forum that you need to disconnect the immbox after the firmware firmware. Please tell me how to do it in 1 time.
    Sorry for my english. Thank you.
    Member KNSelectronica's Avatar
    Jan 2019
    Spain
    Default IMMO OFF
    Hello write this file to eeprom 1 and start the car..
  3. The Following User Says Thank You to KNSelectronica For This Useful Post:
    witrenko (22nd February, 2020)
    Sep 2023
    Is Work ?
