Results 1 to 13 of 13
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Audi S6 dtc help pls
    Vehicle scan but does anyone know where this valve is located
    Address 01: Engine
    1 Fault Found
    001632 - IntakeManifoldTuningValve Control Circuit (Bank 1): Elect. Malfunction
    P0660 - 004 - No Signal/Communication
    Freeze Frame
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 139318 km
    Time Indication: 0
    Date: 2020.02.17
    Time: 15:45:45
    Dec 2017
    South Africs
    On the front of the manifold between the motor and radiator.
  3. The Following User Says Thank You to Limitlesstuning For This Useful Post:
    teerak2uk (18th February, 2020)
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Limitlesstuning View Post
    What's the one next to vacuum point?
    Dec 2017
    South Africs
    so that motor has 2 sets of flaps, one that changes the length of the intake manifold and the other that induces a tumbling charge motion inside the cylinder
  6. The Following User Says Thank You to Limitlesstuning For This Useful Post:
  7. #5
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Trying to do intake flap delete but continually get P0660 dtc
  8. #6
    Dec 2017
    South Africs
    witch flaps are you deleting? the ones that change the length of the intake?
  9. #7
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    The plastic ones which have broke up
  10. #8
    Meat-Head's Avatar
    Can you unplug the electric connector- stop ecu seeing it and wanting it
    #out of sight, out of mind
  11. #9
    Dec 2017
    South Africs
    so have you unplugged the motor already?
  12. #10
    Dec 2017
    South Africs
    you should remove the intake manifold and gut the plastic flaps, the you keep the motor plugged in, the ecu does not monitor its position, so wont throw dtc that way.
  13. #11
    Dec 2017
    South Africs
    Quote Originally Posted by Meat-Head View Post
    If only it was that easy!
  14. #12
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Unless the motor is bad too
  15. #13
    Dec 2017
    South Africs
    well in that case you can always do dtc off in one of the med9 ecus, maby even possible to put a resistor in place..
