Results 1 to 4 of 4
    Top Poster giani03's Avatar
    Default Opel Astra J A17DTR dpf off
    Hello ,
    Need tested solution to disable dpf Opel Astra J 1.7cdti , A17DTR 125HP
    Ecu is DENSO HW nr: 55575080
    In ecu no fault code stored but dpf bulb in dash is blink
    Here is what i read from 7059
    Feb 2019
    Default ASTRA DPF OFF
    Hi. Disconnect temp and dif press sensors.
    Pass=thanks+rep.
    Inform about result
  3. The Following 3 Users Say Thank You to lion1972 For This Useful Post:
    giani03 (18th February, 2020), heatgun (10th August, 2020), nutzicu (9th May, 2021)
    Feb 2019
    Please delete private messages
    Oct 2019
    Italia
    Quote Originally Posted by lion1972 View Post
    Pass=thanks+rep.
    Inform about result
    Is goood Job ��
