Results 1 to 5 of 5
    Senior Member davemac82's Avatar
    May 2008
    Default how to chmod 755
    can anyone tell me how to chmod 755 a file in the var folder using fxp
    Sep 2008
    Don't use fxp but in all other ftp programs I've used you right click the file and select "File attributes..."
    Administrator
    Devilfish's Avatar
    Feb 2008
    chmod - Wikipedia, the free encyclopedia
    Right click the file in your ftp program, select 'chmod' or 'properties' or 'attributes' depending on your program and tick the three 'execute' boxes so that the number changes to 755.
    Or
    You can telnet to the dreambox and use the 'chmod' command.
    For example,
    chmod 755 /var/tuxbox/plugins/footy.so
    May 2008
    thanks guys i will try it out tommorow heres hoping!
    Jul 2008
    Quote Originally Posted by Devilfish View Post
    For example,
    And If you want the chmod the contents of an entire folder
    chmod 755 /var/keys/*
    That will do all the files inside the var/keys folder.
