Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 97
  1. #31
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Here I have made power board to work on 100%, read my post on this thread. You will have to remove one diode ( on original iprog there is no such diode bypass the inverter circuit, and change 4-5 resistors in inverter circuit ) look here:
    https://www.digital-kaos.co.uk/forum...ne-mega-thread
  2. The Following 4 Users Say Thank You to PSAcars For This Useful Post:
    enigmaelectroni (9th May, 2022), fuzz1 (3rd January, 2021), laurentiudania (29th April, 2021), pinotec (4th January, 2022)
  3. #32
    fuzz1's Avatar
    Jul 2019
    Definitely great work. I'm wondering if an external power supply can be added to the iprog to achieve same effect. The power supply with the hard epoxy can't be reworked.
    Thanks for sharing your work
  4. #33
    Viņa del Mar
    Quote Originally Posted by RobertTalker View Post
    Thanks to this post and my effort too. It was only one component that required replacing for the power overload error to go.
    Hello, can you share what you change and with wath components please, tks
    If i can help you just PM, trade and share of softs, not selling
    thanks and rep will always be grateful and cost nothing
  5. #34
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Here you can read my post about power board repair.
    https://www.digital-kaos.co.uk/forum...-thread/page10
  6. The Following User Says Thank You to PSAcars For This Useful Post:
    mariantv (25th April, 2021)
  7. #35
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    My Iprog Power Module, (Tested)
    It can fit on China Clone and Ukraine clone
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  8. The Following 3 Users Say Thank You to hcip For This Useful Post:
    AIDIN R O (19th July, 2021), fuzz1 (24th June, 2021), rybenz (15th August, 2021)
  9. #36
    fuzz1's Avatar
    Jul 2019
    There's a third of pin connecting the main board to the power board. Can't see that on board from hcip. I guess she simplified it.
  10. #37
    hcip's Avatar
    Quote Originally Posted by fuzz1 View Post
    The 3rd Pin on Chinese clone is only a guide not reverse the connection to the main board when you plug this power board, so I marked it which side is correct when plug it on the Chinese Clone main board..
  11. The Following User Says Thank You to hcip For This Useful Post:
    fuzz1 (3rd July, 2021)
  12. #38
    fuzz1's Avatar
    Jul 2019
    Thank you hcip. Nice to see you back. Do you need an oscilloscope to read the different voltages from the power board? Or are the voltages constant on those pins?
  13. #39
    xlv600's Avatar
    Mar 2018
    Rennes (FR)
    Thank you hcip. Nice to see you back. Do you need an oscilloscope to read the different voltages from the power board? Or are the voltages contact on those pins?
    An oscilloscope is not the best tool to test DC voltage. A multimeter on Voltage position is the only tool you need, as well as a continuity tester and the schematics in order to locate the components.
    My clones: CanClip RLT2002, CDP Pro, OBDLink SX & now iProg+
  14. The Following User Says Thank You to xlv600 For This Useful Post:
    fuzz1 (4th July, 2021)
  15. #40
    fuzz1's Avatar
    Jul 2019
    Thank you for your help.
    With a scope it would just be easier to measure instantaneous voltages. I have tried to use the schematics that came with the iprog but the parts do not correspond on the board. Kind of weird why would a cloner change something that works to something that doesn't. Makes no sense just to save a few cents.
    Baffles me really.
  16. #41
    hcip's Avatar
    Baffles me really.
    Schematic from Iprog doesnt help mate.
    as you can see on my Board, I make some modification, Some part are replaced, and value of resistor also changed
    Following what inside the original schematic cannot deliver the stable voltage because of the parts manufacturer difference
    you need to Get a reference from the datasheet of Part to get exact and Stable Voltage...
  17. The Following User Says Thank You to hcip For This Useful Post:
    fuzz1 (5th July, 2021)
  18. #42
    fuzz1's Avatar
    Jul 2019
    Would you be so kind to share the parts that you used?
    And me who thought using ohm's law to get the required voltages by adjusting resistor values.
  19. #43
    fuzz1's Avatar
    Jul 2019
    Hello can anyone tell me the value of the small missing capacitor in the circle? Thanks
  20. #44
    hcip's Avatar
    Very Bad Regulator Board. too many missing part.
    Do it with your own risk.
    if you are not familiar in electronics then Think before you proceed, The output of inverter IC may raise up to 50Volts and may damaged your Atmel Proccesor
  21. The Following User Says Thank You to hcip For This Useful Post:
    fuzz1 (18th July, 2021)
  22. #45
    fuzz1's Avatar
    Jul 2019
    Thank you my friend for your time and patience. I replaced the parts apart from the coil.
    I will look for one. It's a non working iprog so just playing around with it. It's like a piece of puzzle for me. With all the time i spent buying a new one would have been much cheaper. But can't help it the satisfaction of fixing something takes over.IMG_20210718_161953.jpg
