Correct pinout for China Iprog reflash?
https://postimg.cc/LJdWWXww
fuzz1 (13th March, 2023), rtbdiagnostic (24th January, 2023)
Hi i'm new to the forum
i'm looking for solution to the error my iprog.
having log like this:
Test run
--- Test VCC = 3V ---
ADC0 (terminal 41) = 0.0 V. FAULT.
--- Test VCC = 5V ---
--- Test 10/12V ---
Uout = 10V
ADC2 (terminal 43) = 0.0 V. FAULT.
ADC3 (terminal 44) = 0.0 V. FAULT.
Uout = 12V
--- External power test ---
FAULT - EXTERNAL POWER IS NOT CONNECTED.
--- Pin test ---
PORTD.1 (Pin 6): FAULT
PORTE.0 (pin 7): FAULT
PORTE.1 (Pin 8): FAULT
PORTE.2 (pin 9): FAULT
PORTE.3 (pin 10): FAULT
PORTE.4 (pin 23): FAULT
PORTE.5 (pin 24): FAULT
PORTE.6 (pin 25): FAULT
PORTE.7 (Pin 27): FAULT
PORTD.6 (pin 5): FAULT
PORTA.0 (pin 20): FAULT
PORTA.1 (pin 21): FAULT
PORTA.2 (pin 22): FAULT
PORTB.0 (pin 19): FAULT.
PORTB.3 (pin 18): FAULT.
PORTA.5 (pin 2): FAULT.
PORTA.6 (pin 17): FAULT
PORTA.7 (Pin 1): FAULT
PORTB.4 (Pin 16): FAULT
PORTB.6 (Pin 4): FAULT
PORTB.5 (pin 3): FAULT
Test completed. Errors: 28
chinese iprog.
Someone help ?
Did you connect an external power supply?
Nothing seems to work on yours.
Post photos of your boards
333406344_1264467181117482_3062403797491374464_n.jpg333549601_1889438484737268_7551862026974431302_n.jpgIMG_0655.jpg
Moje deski.wydaje się, że brakuje im czegoś, czego
nie podłączyłem do zewnętrznego zasilania
Hi try to remove the diode i circled and check again Attachment 948766
Also check the lm317 to see if they are good.
Sorry this is my power board.I didn't upload that photo
diode removed d3
what voltages must the lm317 have?
one lm317 is missing
