Page 18 of 19 FirstFirst ... 813141516171819 LastLast
Results 256 to 270 of 271
  1. #256
    Karoke
    Last generation of Ford Fiesta, if you lower the rear part of the trim to remove the antenna, then you put trim back in position but no,
    it stay 5mm to 10mm lower than before, no way to gain original position.
    Happened on 5 Fiestas. Had to glue some because the final position was ugly.
    Btw car of 24h surveillance, no one care and if they do I DON'T.
  2. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    rideon (21st October, 2020)
  3. #257
    rideon's Avatar
    RO
    Quote Originally Posted by alessioblaupunkt View Post
    Not sure if this is the surveillance you are talking about..
    The eCall system is designed to improve emergency response times to incidents, and from April 2018 it's a pan-European standard that now has to be fitted to any new model being type approved for sale in the European market.
    Much like the compulsory fitting of daytime running lights to new cars, eCall will only be standard on brand-new cars type approved from April 2018 onwards,
    Old news,nowadays ,when you buy a car, you get a tin can with an VIN and an IMEI .
    Reading this atm, OT ofcourse.
    A failure will not appear till a unit has passed final inspection
  4. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (21st October, 2020)
  5. #258
    Meat-Head's Avatar
    Good point guys
    ON TOPIC:-
    read a Tweet somebody was working on a car, garage, customers car, was doing
    something in the trunk, fuse, bulb, something from nowhere voice “hello emergency services “ guy is like
    ”err umm no”. Operator says “ok you must have pressed a button”
    as for e-call ringing the pigs, there not interested in the uk unless they can make money
  6. The Following User Says Thank You to Meat-Head For This Useful Post:
    rideon (22nd October, 2020)
  7. #259
    rideon's Avatar
    RO
    Recall epidemic for electric and plugin hybrid.
    https://car-recalls.eu/tag/ev-hybrid/
    Hate editing, just remembered...
    https://car-recalls.eu/volkswagen-sc...3-01e4-recall/
  8. The Following 2 Users Say Thank You to rideon For This Useful Post:
    Meat-Head (24th December, 2020), Stelaras26 (27th February, 2021)
  9. #260
    Meat-Head's Avatar
    Honda vcm or something v6 hybrids oil pressure knocked rear cylinder off, causing vacum
    sucking oil up and knack lering engine
    https://m.youtube.com/watch?v=iVGCQ-oUB90
  10. The Following User Says Thank You to Meat-Head For This Useful Post:
    rideon (12th March, 2021)
  11. #261
    Glow plug on pug 407 hdi or C5.
    Maybe engine was intended to be longitudinal mounted so you can easily remove them rather than original transverse position?
    ______
  12. #262
    Mini N47--- diesel engine 130000 km engine blocked by timing chain
    car has had regular service since new.
    Well Mini explain it to the customer.
    Nissan micra dCi 2007, Kia Picanto benzin 2005, Vw Polo benzin 2002, timing chain out of synchro.
    New Ford Fiesta (october 2020 till present) diesel engine require 6 LITERS of 0W30
    (could run a van engine with that amount of oil)
    Alfa Romeo Stelvio diesel - oil filter a little difficult to reach by hand expecially if you are not 2 meters tall.
    Your arm is not long enough to reach the oil filter cup. Need a 32mm fixed spanner to unscrew then continue to unscrew
    with a ratchet 32mm. If you start to unscrew with the ratchet it will flip off the cup every second.
    Oil filter is located in front of the engine, driver side, half height of the engine block, there could be a pipe and a sensor
    hiding it, no worry, pipe is movable but will disturb you forever.
    Once you fit and screw new filter, no way to check with your nail if cup has reached base of engine. No space.
    Alfa Romeo Giulia copy paste, might not have disturbing pipe in front of oil cup.
    ______
  13. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (21st February, 2021)
  14. #263
    Jul 2018
    horncastle,lincs uk
    my brother in law had a nissan primera sports+r,had a duff alternator,nissan dealers said it was engine+box out to remove the bottom alternator bold,i just cut a hole in the inner wing+ removed the bolt then weled a patch over the hole,also jag+ rover 2000 handbrake pads springs to mind!,bastard of a job!!
  15. The Following User Says Thank You to m3vuv2 For This Useful Post:
  16. #264
    Meat-Head's Avatar
    Advertisement:-
    vw toureg alumiun body, held together with STEEL rivets
    does it get electrosis and corrode!
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
  18. #265
    Apr 2015
    Romania
    i just found out about this recall website and i'm amazed to see how bad they messed up.
    https://m.youtube.com/watch?v=iVGCQ-oUB90 this and the video about "the new rotory engine" are interesting
  19. #266
    e-hdi engine 6 hours to remo/fit/decode new alternator(is a starter too)
    Bottom panel + polyv belt cover + right engine support + belt pulley 1 + belt pulley 2 + AC compressor + wiring + clip + intercooler horn 1 + intercooler horn 2 + intake over intercooler + pipes + ALTERNATOR
    repeat reverse.
    Write in ECU new reverse alternator + Write in ECU new polyv belt
    ______
  20. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (1st March, 2021)
  21. #267
    Meat-Head's Avatar
    Body off to do brake pipe
    https://m.youtube.com/watch?v=kB8UX00p5Ws
  22. #268
    clusters's Avatar
    Mar 2015
    Canada
    2007 Toyota Sienna to change lower control arms (3 bolts and 1 ball joint) is 8 hours labor.
  23. The Following 2 Users Say Thank You to clusters For This Useful Post:
    Meat-Head (18th March, 2021), rideon (19th March, 2021)
  24. #269
    Discovery 201X diesel 2.0 at 60.000 km DTCs cam sensor and rpm sensor.
    You think it need timing chain.
    The mechanic do the job: remove engine mount, gearbox, full front and everything necessary to have space, when the floor is FULL
    of Discovery's parts you can do the timing but most program don't have timing chain procedure at the time of writing.
    Found one in a website.
    Remount everything, test the car and...dual turbo noise.
    So at 60.000km timing + dual turbo
    get another car because these engine are known to fatal break at 90.000km for oil pump failure.
    Timing chain remove and refit tempo is 15- 20- 25 hours?
    ______
  25. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (29th August, 2022)
  26. #270
    Jul 2019
    vw electro-hydraulic power steering pumps koyo, trw
