Page 4 of 19 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 271
  1. #46
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    undo and remove 2 of the 3 bolts in the bottom Pully and slacken the 3rd and then turn the Pully up to 12 o'clock , put belt on a turn back to 6 o'clock , bit of tension but not bad , then put bolts back into Pully
  2. #47
    Jun 2011
    Northamptonshire, UK
    Quote Originally Posted by smirnoff_rules View Post
    Yeah that's basicly how I do them... But there is a tool made for the job on that famous auction site.. but all it basically is is a bit of flat bar with a half inch square welded on the end of it to go in hole on tensioner...
    Sent from my HTC One X using Tapatalk 2
  3. #48
    Meat-Head's Avatar
    Quote Originally Posted by Music73 View Post
    Great thanks, i'll get my mom one for christmas.
  4. #49
    Member jimdollar's Avatar
    Oct 2008
    Default Nissan Primera Diesel crank sensor
    Nissan Diesel Crank sensor, for a local taxi firm, the dealer even told him there wasnt one on the car!! But after checking the resistance under the bonnet plug/socket we knew it was faulty but what a pain to remove. I was mobile at the time and had to work under the driver side wing only to find that the senosr went to powder as soon as I tried to remove it with hardly any force.It was fitted down a metal tube,like an ABS sensor and took 6 yes 6 hours to completely dig out with pointy scredrivers etc, I got do fed up with it I did 2 hours at a time, there was no way to get the new one in till the housing was completely empty of old one. I later had another one on another car and said" NO WAY!!" to customer but guess what that one came out no bother!!
  5. #50
    Meat-Head's Avatar
    now you said that ford focus speedo sensor, we out bid took 8 hours we charged costomer 4 hours for it.
    drilled round the outside made the drillings an additive
    reno most models check let alone changine fuses
    reno clio sunroof, no smeg just double sided tape then wounder why they leak!
  6. #51
    Member anthony610's Avatar
    ireland
    THE FERNCH SHOULD ONLY BE ALLOWED TO MAKE CROSSANTS!!!
  7. #52
    rideon's Avatar
    RO
    Quote Originally Posted by anthony610 View Post
    PLEASE!! Don't get me started on this one!!
    1. french....
    2 Germans skipped the lesson named "how to build a petrol engine"
    3 emmericans skipped the one called"how to steer a car"
    and SOO ON!!!!
    A failure will not appear till a unit has passed final inspection
  8. #53
    Meat-Head's Avatar
    Quote Originally Posted by rideon View Post
    UNSURE IF ON TOPIC OR OFF TOPIC:-
    Mercedes SBC braking was that right there is a motor on the brake calipers?
    Just nicked a set of alloys from the parking lot over the road, way going to skank the calipers as well, but just brake pipe no motor wires?
    ON TOPIC:-
    Audi TT - front wheel nuts, took a LOT of effort to remove the wheels.
    We put the nut on FINGER TIGHT, drove out in the parking lot, drove back in, took a LOT of effort to get back off again.
  9. #54
    Dec 2012
    Quote Originally Posted by racin-snake View Post
    but the best one ive seen is the alfa romeo 2.5 and 3.0 timing belts
    Quote Originally Posted by BeianM View Post
    Both my favourite cars
    2ltr Alfa 156 Sportswagen
    Had loads of fun with my 156 v6.
    Cambelt was a bitch for me doing it as a complete novice with basic tools years ago. (Later checked timing with blocks and it was spot on).
    Half my bolts seem to have turned to rust - all four bolts on both headlights snapped - thought I would change the wings and slam panel to sort this then 3 out of four bolts holding the slam panel to chassis leg snapped.
    However nothing I had ever seen on my Alfa could prepare me for working on french cars.
  10. #55
    DK Veteran m3vuv's Avatar
    woodhall-spa lincs
    nissan primera 2.0l sports +R,alternator change,bottom alternator bolt fouls on inner wing so wont come out,rang main agent to pick there brains,guy on the other end of the phone,yes mate its engine and box out mate!,wtf,engine and box out to change an alternator!!,hole saw on the inner wing and a big grommet later,1hr later job done!
  11. #56
    Meat-Head's Avatar
    Quote Originally Posted by m3vuv View Post
    yeah sort of second that, unless thinking pug 405/pug406 agree
    seem to think stuff a jack under it and away
    PRE-EDIT
    pug has a notch out the alternator
  12. #57
    Citroen XM 2.5 - to remove inlet manifold, disconnect jungle of pipe work then find you need it up in the air to get your arm (up to your elbow) in the gap between the subframe/exhaust down pipe/body with a 2 foot long screwdriver to remove EGR clip....
  13. #58
    Meat-Head's Avatar
    Quote Originally Posted by steelcityuk View Post
    Citroen XM 2.5 -
    remove EGR clip....
    i hope this is old info not the fact somebody has an XM still.
    how do you put the clip back on?
  14. #59
    Still have a K reg XM. In fact it's her birthday this month, she's 20. But this one's a 2.1. The clip goes on exactly the same way as it comes off, I guess a helper could hold it in place whilst you struggle underneath up to your elbows in crap. That said I found that if you removed the right wheel and liner it could be done much easier - read that as 'real pain in the arse'. I've bought 2 scenics to keep her company...
  15. #60
    Meat-Head's Avatar
    after one frogench car you wount have though you would have another one.
