Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Jun 2019
    Default SD Connect C4 can't connect with Smart 451
    Hi. I have tried connecting my SD Connect C4 to a Smart 451, DAS can read VIN code but when connecting to the ECU it takes a long time and then ask to switch the ignition on.Key is on the ignition, tried switching it off and on bt no luck. On Smart 450 and 452 it works perfectly.
    It seems there is some communication problem in the unit (Possibly the canbus circuitry), tried with two cars today and no luck. Also tried with another cable. Any idea wher to start looking?
    Jun 2019
    Opened the mux and had a butchers on the relay board. Not the highest quality clone, the board have no chokes and Fujitsu relays. Cleaned some flux residue from board.
    All the relays checked, coils measure close to 145Ω, terminals 2 and 3, 7 and 6 are connected when the coil is not energized. Have yet to test to power the coils and check 3 and 4, 6 and 5.
    Jun 2019
    Forgot to update this thread.
    Removed the 0 Ohm resistors and installed the common mode chokes. Now it connects to Smart 451 cars without issue.
  4. The Following User Says Thank You to SAMDoctor For This Useful Post:
    Julesd (4th September, 2022)
    Apr 2011
    Hi SAMDoctor,
    I have a Smart 5WK4 5090 V005
    with no canbus communication,
    can you give me any pointers to try please?
    Thanks,
    Jules.
  6. #5
    Apr 2011
    Just opened it up and seen breaks in the flexi joining the PCB's.
    Please see photo attached.
    Looks like it could be the problem?
    What do you think please?
  7. #6
    Jun 2019
    No, those are not an issue at all.
    Was there any corrosion on the CPU board?
  8. #7
    Apr 2011
    Thanks for the quick reply.
    Can't see any corrosion at all,very clean (Top board at least) can't see underside though
  9. #8
    Jun 2019
    That SAM is a 450 model. There is no canbus to the obd connector, try with K line.
  10. #9
    Apr 2011
    It came in with no canbus issue. Are you saying it doesn't work on canbus, just Kline?
  11. #10
    Apr 2011
    Just stripped it down.
    I see what you mean now, those gaps on the flexi are not tracks!
  12. #11
    Apr 2011
    Just seen some dry joints mainly on tracks coming from fuses.
    Could it still be causing communication issues?
  13. #12
    Apr 2011
    Default Photo
    Attached photo.
    Thanks.
  14. #13
    Jun 2019
    Yes, no canbus to the diagnostic connector. There are two different canbus on the SAM, one goes to the cluster and another one to the MEG (ECU)
  15. #14
    Apr 2011
    Thanks,
    Could these dry joints be causing communication problems, even they they seem to be coming from fuses?
  16. #15
    Jun 2019
    Those are not dry joints. Those are cracked, because of the vibration. They might be the reason, because the power to the ECU goes through these.
