rideon (21st October, 2020)
Karoke
Last generation of Ford Fiesta, if you lower the rear part of the trim to remove the antenna, then you put trim back in position but no,
it stay 5mm to 10mm lower than before, no way to gain original position.
Happened on 5 Fiestas. Had to glue some because the final position was ugly.
Btw car of 24h surveillance, no one care and if they do I DON'T.
Not sure if this is the surveillance you are talking about..
The eCall system is designed to improve emergency response times to incidents, and from April 2018 it's a pan-European standard that now has to be fitted to any new model being type approved for sale in the European market.Old news,nowadays ,when you buy a car, you get a tin can with an VIN and an IMEI .Much like the compulsory fitting of daytime running lights to new cars, eCall will only be standard on brand-new cars type approved from April 2018 onwards,
Reading this atm, OT ofcourse.
A failure will not appear till a unit has passed final inspection
Meat-Head (21st October, 2020)
Good point guys
ON TOPIC:-
read a Tweet somebody was working on a car, garage, customers car, was doing
something in the trunk, fuse, bulb, something from nowhere voice “hello emergency services “ guy is like
”err umm no”. Operator says “ok you must have pressed a button”
as for e-call ringing the pigs, there not interested in the uk unless they can make money
rideon (22nd October, 2020)
Recall epidemic for electric and plugin hybrid.
https://car-recalls.eu/tag/ev-hybrid/
Hate editing, just remembered...
https://car-recalls.eu/volkswagen-sc...3-01e4-recall/
Meat-Head (24th December, 2020), Stelaras26 (27th February, 2021)
Honda vcm or something v6 hybrids oil pressure knocked rear cylinder off, causing vacum
sucking oil up and knack lering engine
https://m.youtube.com/watch?v=iVGCQ-oUB90
rideon (12th March, 2021)
Glow plug on pug 407 hdi or C5.
Maybe engine was intended to be longitudinal mounted so you can easily remove them rather than original transverse position?
Mini N47--- diesel engine 130000 km engine blocked by timing chain
car has had regular service since new.
Well Mini explain it to the customer.
Nissan micra dCi 2007, Kia Picanto benzin 2005, Vw Polo benzin 2002, timing chain out of synchro.
New Ford Fiesta (october 2020 till present) diesel engine require 6 LITERS of 0W30
(could run a van engine with that amount of oil)
Alfa Romeo Stelvio diesel - oil filter a little difficult to reach by hand expecially if you are not 2 meters tall.
Your arm is not long enough to reach the oil filter cup. Need a 32mm fixed spanner to unscrew then continue to unscrew
with a ratchet 32mm. If you start to unscrew with the ratchet it will flip off the cup every second.
Oil filter is located in front of the engine, driver side, half height of the engine block, there could be a pipe and a sensor
hiding it, no worry, pipe is movable but will disturb you forever.
Once you fit and screw new filter, no way to check with your nail if cup has reached base of engine. No space.
Alfa Romeo Giulia copy paste, might not have disturbing pipe in front of oil cup.
Meat-Head (21st February, 2021)
my brother in law had a nissan primera sports+r,had a duff alternator,nissan dealers said it was engine+box out to remove the bottom alternator bold,i just cut a hole in the inner wing+ removed the bolt then weled a patch over the hole,also jag+ rover 2000 handbrake pads springs to mind!,bastard of a job!!
Advertisement:-
vw toureg alumiun body, held together with STEEL rivets
does it get electrosis and corrode!
i just found out about this recall website and i'm amazed to see how bad they messed up.
https://m.youtube.com/watch?v=iVGCQ-oUB90 this and the video about "the new rotory engine" are interesting
e-hdi engine 6 hours to remo/fit/decode new alternator(is a starter too)
Bottom panel + polyv belt cover + right engine support + belt pulley 1 + belt pulley 2 + AC compressor + wiring + clip + intercooler horn 1 + intercooler horn 2 + intake over intercooler + pipes + ALTERNATOR
repeat reverse.
Write in ECU new reverse alternator + Write in ECU new polyv belt
Meat-Head (1st March, 2021)
Body off to do brake pipe
https://m.youtube.com/watch?v=kB8UX00p5Ws
2007 Toyota Sienna to change lower control arms (3 bolts and 1 ball joint) is 8 hours labor.
Please DO NOT PM me asking for help.
Post in the forum, that is what it is here for.
Discovery 201X diesel 2.0 at 60.000 km DTCs cam sensor and rpm sensor.
You think it need timing chain.
The mechanic do the job: remove engine mount, gearbox, full front and everything necessary to have space, when the floor is FULL
of Discovery's parts you can do the timing but most program don't have timing chain procedure at the time of writing.
Found one in a website.
Remount everything, test the car and...dual turbo noise.
So at 60.000km timing + dual turbo
get another car because these engine are known to fatal break at 90.000km for oil pump failure.
Timing chain remove and refit tempo is 15- 20- 25 hours?
Meat-Head (29th August, 2022)
vw electro-hydraulic power steering pumps koyo, trw
