I can to do write me.
WinOLS+damos=dtc off
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
p307a - need to clean the throttle
Don't forget hit thank button if i helped.
Monday,24,February,2020,16:13:13:00001
VCDS Version: Release 17.8.0 Running on Windows 7 x86
www.ross-tech.com
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP82.clb
Control Module Part Number: 6R0 907 379 AF HW: 6R0 907 379 AF
Component and/or Version: ESP8.2i front H05 0005
Software Coding: 210228E3216E00B6842D14EB84D700401300
Work Shop Code: WSC 02069 000 00000
VCID: 020AB294990F10569C-8056
2 Faults Found:
01314 - Engine Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 2
Reset counter: 7
Mileage: 141325 km
Time Indication: 0
Date: 2049.14.27
Time: 16:10:37
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3224
Hex Value: 0x1496
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7E00
03306 - Coding Not Valid
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 7
Mileage: 141325 km
Time Indication: 0
Date: 2049.14.27
Time: 16:10:37
Freeze Frame:
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3203
Hex Value: 0x2596
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7E00
Monday,24,February,2020,16:12:44:00001
www.ross-tech.com
Address 01: Engine Labels: 03F-906-070-CBZ.clb
Control Module Part Number: 03F 906 070 D HW: 03F 906 070 D
Component and/or Version: SIMOS10.20H02 9851
Software Coding: 00000000000000000000
Work Shop Code: WSC 124697 483 00190
ASAM Dataset: EV_ECM12TFS02103F906070D 003015 (VW25)
ROD: EV_ECM12TFS_003_VW25.rod
VCID: 2344D7102AD5F95EB7-8076
2 Faults Found:
6441 - Accelerator Position Sensors (G79) / (G185)
P2138 00 [165] - Implausible Correlation
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 141325 km
Date: 2113.14.27
Time: 16:08:15
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 42 °C
Intake air temperature: 28 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.780 V
Unlearning counter according OBD: 40
Engine speed: actual: 0 /min
11014 - Accelerator Position Sensors (G79) / (G185)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 141325 km
Date: 2113.14.27
Time: 16:08:15
Readiness: 0110 0101
quattro210 (23rd August, 2020)
test this file and report.
Hi there how can i read this Ecu? Galetto and Kess V2 failed
