Results 1 to 6 of 6
    Ecuprog31's Avatar
    Mar 2018
    Default Toyota verso 2011 D4D DENSO B2799
    Hi all
    I have a problem with toyota verso 2011 D4D
    b2799 in ECU
    NO Dtc in immobox
    immo turn off when I insert key ( 3 keys )
    ive did jump pin on obd
    i programmed keys with lonsdor
    but still no crank
    i checked immo wires
    can I do immo off on denso 89661-0F340
    Ecuprog31's Avatar
    Mar 2018
    Help please
    Nov 2017
    Did you lost the key? Because if immo light turn off when you insert key it means it's seeing the key so if the car doesn't start it might be a different problem
    Ecuprog31's Avatar
    Mar 2018
    Immobox and keys are ok
    led turn off when I insert keys
    but in ECU B2799 immo problem
    Ecuprog31's Avatar
    Mar 2018
    Immo off possible denso toyota 89661-0f340??
    Ecuprog31's Avatar
    Mar 2018
    Up up up please
