Results 1 to 3 of 3
    Jan 2014
    Default EDC16C34 CITROEN C5 DPF ADDTIVE OFF
    Please i need dpf and additive off
    for citroen c5 edc16c34
    0 281 013 872
    Best regards.
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    HI FRIEND
    DPF OFF, CHECKSUM CORRECTED
    FOR ADDITIVE Disconnect the Fuel additive module and remove the DTC inside ecu
    And with Diagbox LEXIA Decode the additive module from BSI as NOT PRESENT
    REPORT BACK
    THANKS
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  3. The Following 2 Users Say Thank You to momogsm For This Useful Post:
    chafik4051 (20th February, 2020), ordabg (21st February, 2020)
    Jan 2014
    thank you my friend for help.
  5. The Following User Says Thank You to chafik4051 For This Useful Post:
    momogsm (20th February, 2020)
