Results 1 to 7 of 7
Thread: Edc16c9
    Feb 2020
    Default Edc16c9
    Got a broken in a car crash edc16c9 , the pcb is bended and will not read with any bdm.
    Bought a 2nd one same hardware and my plan is to take eeprom and am29bl802cb chips from broken one and put them on the new one. Can t swap mpc556 as needs reballing and would be a high risk to do it.
    Now wondering... will this make 2nd ecu fully compatible with the car or shall i expect some troubles?
    Thanks all...
    Jul 2017
    if can't read original ecu and second ecu is same hw numbers, then do ecu virgin and start the car, which model of the car?
    Feb 2020
    I removed eeprom from broken one and i have dump file aswell.. the new ecu can be read with ktag so wondering if I reprogram it with eeprom dump from broken one will be ok?
    Car is opel astra H
    Feb 2020
    I can t get mpc556 chip to be read from broken one so wondering if there is any critical info in there that is needed in the new ecu...
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Allecsxx View Post
    if your tool has option for read mpc, then there could also be different data which is needed for cloning...
    of find same HW/SW no donor ecu, then you have chances that the data is same...
    Feb 2020
    I ve got exactly same hardware but don t know about sw as i can t read
    Feb 2020
    New ecu was for same engine as broken one
