Results 1 to 5 of 5
    Default Fiat Stilo 5NF T9 hw102
    Allready try to virgin and relearn but not working
    Somewhere lost communication between bcm and ecu
    So if possible please immo off for it.
    Have virginise,relearn
    Car started twice then again not starting.
    Cut pin 16,join to pin 12 again virgin,but not starting.
    When no immo of work,then only emu wil solve this.
    Anybody, some ideas?
    Have found why nothing work.
    Ecu defect.
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by sepistar View Post
    Ecu defect.
    Classic ecu!
    Try Heating mcu for some time,and let it get cold without doing anything else,this mostly heals the problem of no communication.
    Also check pins,and resolder.
    If i Helped you,use thanks and rep button to thank me back
  6. The Following User Says Thank You to Stelaras26 For This Useful Post:
    Meat-Head (1st March, 2020)
