Hello test this file please, its for car with AC, if your car has no AC let me know will send you another file.
Make write protection on the EEPROM..
Nicolas13007 (22nd February, 2020)
thanks mate i will try it monday and report back
Hi mate wich tool has the option write protect for this eeprom as i have Upa 1.3 and has no write protect for this eeprom
Use Upa-S like Rafal said and write 8C on Status register...
rafal (27th February, 2020)
Done mate It is not working ,,immo is blinking
Is there any one who has another solution ? any help is welcome
You done write protecion on the eeprom. If immo blinking not said that the file its not OK... I have no more solutions for this ecu,sorry. Its very important to do write protection on the eeprom,if you not do it like this, please repeate the procedure and maybe disconect the antena coil.
I dont have another solutions for this,sorry. Good luck.
Hello,
Test this solution and report.
Not working mate , do i must write in write protect
Hello friends problem solved , if you have the original ECU and the car dont start just replace all the data from the range 150 to the end with zero
