Results 1 to 7 of 7
    May 2014
    Default 2008 Toyota Prius smart key
    Hello
    i have 2008 toyota prius hybrid with all key lost
    i found this smart unit ecu 8990-47023
    file was read but Tango says unknown version .
    i need help to get this cart start
    thanks in advance
    ekas's Avatar
    Jan 2016
    Kyrgyzstan
    This car need program through OBD.
    narkeleptk's Avatar
    May 2017
    USA
    Don't you need immo box? This year prius in the states has immo for transponder then smart box for remote function I think. (always done them obd)
    brownbajan's Avatar
    Feb 2009
    the islands
    you need to have a smartkey, read the key data, post it
    Apr 2014
    i have same problem.
    i read eeprom as 93c66 and Tango says unknow Data
    ekas's Avatar
    Jan 2016
    Kyrgyzstan
    Use techsream for this car or another tool through OBD.
    ray-ray's Avatar
    93c66 did you read it in 8bit mode or 16bit mod. I have learn that most 93c66 gets read as 8 bit mode and write chip in 16bit mode. The same goes for 93c56 read in 16bit. Mode and write the chip in 8 bit mode.
