DTC P0011 disable or remove Citroen C1 1KR-FE
Results 1 to 10 of 10
    Feb 2020
    4
    Downloads
    Uploads
    Default DTC P0011 disable or remove Citroen C1 1KR-FE
    Is there anyone who can help me with DTC remove on this ECU?
    AUTODIAG666's Avatar
    Feb 2020
    FRANCE
    3
    Downloads
    Uploads
    yes put your dump
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
    Dpf Removal,Egr Removal,AdBlue Removal,Dtc Removal,Immo Removal,Crash Data-Clear.
    Feb 2020
    4
    Downloads
    Uploads
    Hello, very nice you will help me. Here is de dump
    Feb 2020
    FRANCE
    3
    Downloads
    Uploads
    I don't think you had the ecu type ? BOSHE
    Feb 2020
    4
    Downloads
    Uploads
    Yes i have, see the picture. do you need the complete file including eeprom file?
    Feb 2020
    FRANCE
    3
    Downloads
    Uploads
    ECU ME7.9
    HAVE YOU MODIFIED ALL SOFT FIND NOTHING ELSE AND THE FAILURE?
    Feb 2020
    4
    Downloads
    Uploads
    The failure is P0011 is going away if i take it from the power. When i put it on the DTC is gone. Have to drive for 5 minutes ant the is the dtc back. But like i said...... its away as soon i take it to my KTAG.
    Feb 2020
    FRANCE
    3
    Downloads
    Uploads
    SORRY MY FRIEND I CANNOT FIND DTC IN THE CORTO I HOPE FOR YOU HELP FROM ANOTHER SORRY
  9. The Following User Says Thank You to AUTODIAG666 For This Useful Post:
    Henkaudi (23rd February, 2020)
  10. #9
    EUROPE
    238
    Downloads
    67
    Uploads
    You must change timing chain kit.i had same code on same car
  11. The Following User Says Thank You to kospoz For This Useful Post:
  12. #10
    Member Pepesoft's Avatar
    Jan 2017
    Finland
    34
    Downloads
    8
    Uploads
    Quote Originally Posted by Henkaudi View Post
    Common fault on those cars. Check that if the VVT solenoids are leaking oil. If are you really should change the solenoid rather than remove dtc. Not hard to change and quite cheap parts.
