Read Dump from from ECU
I have VW Polo 1.2 MY2011.
Getting below error code in VCDS
Address 01: Engine (CJL) Labels: None
Part No SW: 03E 906 023 AQ HW: 03E 906 023 P
Component: SIMOS91 1.2l 4V 6936
Revision: --H05--- Serial number: 00000000000000
Coding: 0000001
Shop #: WSC 01234 785 00200
VCID: 6ED311FC7A70753F45-5124
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 006 -
Readiness: 0110 0101
How do I turn off IMMO. Does it requires dump from ECU or Dashboard?
see picture
Manage to get IMMO off dump for ECM but still getting
P1570 - 006 -
Is there anything else to be done?
Filled offset 06 to 0B with 31 but still getting 17978 - Engine Start Blocked by Immobilizer error and ECM is again filled with original value in offset 06 to OB.
Please help
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
