Car starts and work fine?
And ktag dont work?
the car starts and I don't have the k tag ... I have to do a dpf off but I don't read it ... the rework of the kess was done by the guide of this site
this ecu is locked by default, either do it obd2 with VR or unlock it in boot mode
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
It can be done with virtual read and obd.
If it's locked...
It can be done with the most of ori tools by obd...
It needs to be done on bench and or opened...
If it's unlocked before, even a kess Clone can do it by obd...
blocked means that it does not recognize even id?
It's best to desolder eeprom with PCR2.1 and insert here to unlock or unlock it yourself
240A to 252
xx xx xx xx xx xx xx xx XOR FF FF FF FF FF FF FF FF FF
There is memory
25640
Read the content and insert here. This will be the best
Then you can use OBD kess for reading
elmer9 (28th February, 2020)
k-tag clone works well
kess clone don’t work
even kess clone works if someone can get your matching VR from alientech
k-tag flex pinout unlock pcr2.1 no need open
Ktag only original
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
Unlock then read-write works fine with Kess V2 clone, but obviously genuine tools are best - can be done full OBD no unlock with genuine Kess V2
