Any Yanke from US can help please?
It is the same vehicle as ASX.
But maybe it is easier to do, since it is a US version.
From K518 web.
MITSUBISHI\Select from vehicle\America\USA\Rvr\Without smart\-2012 Program key,
MITSUBISHI\Select from vehicle\America\USA\Rvr\Without smart\2012- Program key,
holbi1 (23rd February, 2020)
is it a smart key or bladed one? obdstar, avdi, lonsdor can do
Is bladed key
Tools that i stated earlier can do it
Did anyone figured out how to program remote on this POS (2014 Mitsubishi RVR, non-smart key)?
Spent more than hour today, no luck. First of all, Autel has this car in the menu, but suggests different procedure for remote matching comparing to old Mitsubishi models. Instead of "hold lock+unlock 3 blinks, then unlock 3 blinks" Autel tells "hold lock+unlock 5 blinks, then hold unlock 2 blinks, and after you release unlock, light should blink 1 more time". I know for a fact that Autel gives totally incorrect programming procedure for some cars, including Toyotas, so I wouldn't bet on it.
The weird part is - customer's original key (regular diamond shaped key) does that, and can be programmed back to the car (as all remotes are wiped during programming), but all other keys that I have (and I have more than 50 of them!) while have exactly same FCC ID, behave differently - they only do 3 fast flashes, and then stop flashing at all! I've tried everything I could imagine - no success.
Lonsdor has no remote programming available in menu for this model (or I couldn't find it in the rush, I guess I should go by the system, not by the model. RVR menu only has key (chip) programming. I did try to program key in hope remote might be programmed together with chip - nope, it didn't. Key programmed though), AutoProPad did its usual thing - from it's remote screen only Type 1 comes through (other types - connection error), but when you actually try to program - it wipes existing remote and doesn't program any back to the car. How nice!
Then I gave up and made KEYDIY key with same FCC ID. It only flashes when holding ONE button! When I'm holding lock+unlock - no flashes at all!
Many people say Mitsubishi is pain in the a** to program, but this is complete joke.
Did anyone have success with these?
this is pain in the ass with keydy, not work generate wrong key car start remote not working .So i buy orginal from us pcf 7941 mitsubishi key renewed with baracuda and keydi still the same .I think must be new oem key or they sell me broken key .Lonsdor make procedure ok as us rvr or asx the problem is key my friend
exacly 3 flasing and off same as me
Well, like I said - I have tons of these keys and circuit boards, many of them still locked (used), I also have many Chinese boards for this diamond shaped key, but ALL behaving same way - just 3 flashes. I remember earlier this year I had success with newer Lancer, VVDI key and Lonsdor. This time didn't try Lonsdor "by system", maybe this was my mistake.
Little update on this. 2015 Lancer - exactly same thing - older remote can not be programmed.
This is another joke from manufacturer - key has exactly same appearance, exactly same FCC ID, exactly same looking board inside, but newer keys (around 2015 and newer) behave differently - they give constant signal, so they can be programmed to newer models (5 flashes "lock+unlock", then 2 flashes "unlock"). All older keys just do 3 flashes, then stop transmitting. Keydiy key won't work either. Apparently, VVDI remote OUCG8D-625M-A 1675 gives constant signal, so possibly it can be programmed to newer models (haven't tried yet).
