Results 1 to 4 of 4
    EUROPE
    Default lancia delta 1.6 tdi
    hi all i am having a strage problem with selespeed from this car.
    When car get warmed and put the lever to N then gearbox can not put other gear and flashes the symbol from hook and has error for temperature.If it be cold gearbox is working again.
    Also if i am waiting with A in gear car is shaking a lot.When i put it to N all fine no vibrations.
    Car has 150000 km.
    Can be the flywheel the reason for all that?
    Meat-Head's Avatar
    Sounds like the fluids in gearbox have got contaminated with all the dk thanks you not used
    and causing it to over heat.
    are brakes stuck on?
    does it have gearbox oil cooler that blocked?
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    kospoz (23rd February, 2020)
    EUROPE
    I saw the fluid into reservoir for selespeed and is ok very clean and brakes working fine.
    This type not has oil cooler.
    If we accept that fluid is the problem why we have vibrations with gear on and brake pushed?
    Meat-Head's Avatar
    Does point towards it.
    pull box out send for checking fit new clutch
