Results 1 to 11 of 11
    Mar 2017
    Default NEED MAPS LABELED PLEASE...
    Can someone please label/Identify these maps locations on Winols for me MY car is VW Jetta 2.0TfSI ECU Bosh Med 9.1
    1C3134
    1C475E
    1C48AA
    1C4A3C
    1C4F62
    1C548E
    1C643A
    1C7F36
    1C8B52
    1C9A62
    1CA35A
    1CA3DA
    1CA45A
    1CA4DA
    1CA55A
    1CA5DA
    1CAA74
    1CAE70
    1CAEF0
    1CAF70
    1CBFC4
    1CC180
    1CC8A6
    1CD358
    1CD3A2
    1CD742
    1CD7E6
    1CEAE4
    1CF214
    1CF76A
    1CF9C0
    1CFAFA
    1CFD2C
    1D0F60
    1D1004
    1D10A8
    1D2A30
    1D2EDE
    1D3674
    1D3710
    1D37B4
    1D3938
    1D39BE
    1D3E64
    1D418A
    1D4276
    1D469E
    1D483A
    1D64C4
    1D6972
    1D69D6
    1D6CF0
    1D6EA4
    1D7AAC
    1D8C32
    1D8CDE
    1D8DF4
    1DC1D4
    1DC390
    1DC54C
    1DC8D4
    1DC9A2
    1DCA22
    1DCAA2
    1DDBC2
    1DE75C
    Jun 2013
    EU
    Only those you need?
  3. The Following 2 Users Say Thank You to morgano For This Useful Post:
    Ignasvw (24th February, 2020), Lambda1 (26th February, 2020)
    Mar 2017
    Quote Originally Posted by morgano View Post
    Yes please these are my "Potential maps" but i have no idea what is what
    Aug 2012
    Quote Originally Posted by Brycbenn View Post
    :-D
    u think anyone know what software number u have . and nobody has the time to make mappacks for free :-)
    and the users that can do has original ols
    and this not wrk at yours
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Jul 2015
    Not all potential maps are maps
    not all maps are required for tuning.
    what you are asking for will take many hours...
    even if you know what these maps are for ,its most likely you wont know what to do with them if you are unable to find them yourself,
    i recommend you buy a tuning file from a legit company.
    also wheres the ecu id? the binary?
    Mar 2017
    2006 VW 2.0TFSI
    Producer:Bosh
    Build:Med9.1
    ECU NR.Prod. 1K0907115B
    ECU NR.Ecu 0261S02080
    Softwear 1037391667
    Eprom 5141
    Mar 2017
    Mainly just need the ones that have to do with
    boost
    Timing
    Fuel
    If someone could just help me label those out of the list please.
    Aug 2012
    Adresse;Bezeichnung;Größe
    $1C32DA;Kennfeld für Offset-Toleranz in Abhängigkeit vom zulässigen Moment (!);8x8
    $1C32DA;Kennfeld für Offset-Toleranz in Abhängigkeit vom zulässigen Moment;8x8
    $1C331A;Kennfeld 0 für rel. zul. Moment aus der Pedalstellung in der Momentenüberwachung (!);8x8
    $1C331A;Kennfeld 0 für rel. zul. Moment aus der Pedalstellung in der Momentenüberwachung;8x8
    $1C335A;Kennfeld 1 für rel. zul. Moment aus der Pedalstellung in der Momentenüberwachung (!);8x8
    $1C335A;Kennfeld 1 für rel. zul. Moment aus der Pedalstellung in der Momentenüberwachung;8x8
    $1C4A3C;ML-Schwelle für B_maxflr-Diagnose HFM/HLM;9x8
    $1C4AF2;Korrekturkennfeld für HFM;14x14
    $1C7F36;Korrekturfaktor Kraftstoffversorgungssystem;8x8
    $1D5D12;Kraftstoff masse split faktor im HKS Double ES;8x8
    $1C847D;Zündwinkelkennfeld bei geschlossener Ladungsbewegungsklappe;12x16
    $1C853D;Zündwinkelkennfeld Variante 2 bei geschlossener Ladungsbewegungsklappe;12x16
    $1C823D;Zündwinkelkennfeld (!);12x16
    $1C823D;Zündwinkelkennfeld;12x16
    $1C82FD;Zündwinkelkennfeld Variante 2 (!);12x16
    $1C82FD;Zündwinkelkennfeld Variante 2;12x16
    $1C8641;Min-Zündwinkel Katheizen(HSP);12x18
    $1C8719;Kennfeld für Minimal-Zündwinkel bei BDE-Betriebsartenumschaltung;12x18
    $1C87F1;Kennfeld mit dauerhaft spätest möglichem Zündwinkel bei aktiver Ladungsbewegung;12x18
    $1C90B6;Maximaler Referenzpegel für Klopferkennungsschwelle Zyl.-gruppe 1;16x1
    $1C90D6;Maximaler Referenzpegel für Klopferkennungsschwelle Zyl.-gruppe 2;16x1
    $1C8FB6;Klopferkennungsfaktorkennfeld Zylinderzähler 0 (!);4x16
    $1C8FB6;Klopferkennungsfaktorkennfeld Zylinderzähler 0;4x16
    $1C8FF6;Klopferkennungsfaktorkennfeld Zylinderzähler 1 (!);4x16
    $1C8FF6;Klopferkennungsfaktorkennfeld Zylinderzähler 1;4x16
    $1C9036;Klopferkennungsfaktorkennfeld Zylinderzähler 2 (!);4x16
    $1C9036;Klopferkennungsfaktorkennfeld Zylinderzähler 2;4x16
    $1C9076;Klopferkennungsfaktorkennfeld Zylinderzähler 3 (!);4x16
    $1C9076;Klopferkennungsfaktorkennfeld Zylinderzähler 3;4x16
    $1C92B4;;1x1
    $1C92B2;Überschreitung der Maximaldrehzahl für Einspritzausblendung an allen Zylindern;1x1
    $1C93F9;Kennfeld für Offset-Toleranz in Abhängigkeit vom zulässigen Moment (Ebene 1) (!);8x8
    $1C93F9;Kennfeld für Offset-Toleranz in Abhängigkeit vom zulässigen Moment (Ebene 1);8x8
    $1C9439;Kennfeld für rel. zul. Moment aus der Pedalstellung in der Momentenbegrenzung (!);8x8
    $1C9439;Kennfeld für rel. zul. Moment aus der Pedalstellung in der Momentenbegrenzung;8x8
    $1C9479;Kennfeld für rel. zul. Moment aus der Pedalstellung in der Momentenbegrenzung (!);8x8
    $1C9479;Kennfeld für rel. zul. Moment aus der Pedalstellung in der Momentenbegrenzung;8x8
    $1C9432;Klopferkennungsfaktorkennfeld Zylinderzähler 0 (!);4x16
    $1C9432;Klopferkennungsfaktorkennfeld Zylinderzähler 0;4x16
    $1D87BE;I-Anteil des NMAX-Reglers;8x4
    $1C9E8C;Zulässige Verminderung der Maximaldrehzahl pro Rechenschritt;1x1
    $1C9E8E;Delta zwischen Soll- und Istdrehzahl für Abschaltung NMAX-Regelung;1x1
    $1C9E90;Delta Drehzahl, bei der keine Zündwinkeleingriff stattfindet;8x1
    $1C9EAA;Delta- Korrektur für Intialisierung des I-Anteils;4x1
    $1C9EB4;CWDVMX;1x1
    $1C9E8B;Zeit für Delta Drehzahl, bei der keine Zündwinkeleingriff stattfindet;1x1
    $1C9EB2;Drehzahlbegrenzung;1x1
    $1CBFC4;Kennfeld für Berechnung Sollfüllung;12x16
    $1CC180;Kennfeld für Berechnung Sollfüllung;12x16
    $1CC8A6;Kennfeld optimales Motormoment;11x16
    $1CCA06;optimaler Zündwinkel;11x16
    $1CCAB6;optimaler Zündwinkel Variante 2;11x16
    $1CCB66;Optimaler Zündwinkel, Ladungsbewegungsklappe Schichtstellung;11x16
    $1CCC16;Optimaler Zündwinkel (Variante 2), Ladungsbewegungsklappe Schichtstellung;11x16
    $1CD6DE;Kennfeld für Wichtungsfaktor Grundladedruck als f(tans);8x8
    $1CD742;Deltadruckabweichung Grundladedruck für Höhe;8x8
    $1CD7E6;Grundladedruck für Basishöhe (Umgebungsdruck);8x8
    $1CD886;Max. zulässiges Druckverhältnis DK für ldra Diagnose;12x10
    $1CDE8C;Zeitkonstante für langsame LDR-Aufregelung;8x1
    $1CDE9C;Zeitkonstante für schnelle LDR-Absenkung;8x1
    $1CDEAC;Zeitkonstante für schnelle LDR-Aufregelung;8x1
    $1CDEBC;Maximalfuellung LDR bei E_ldo (Überladefehler);8x1
    $1CDECC;Rl-Schwelle für langsamen LDR-Eingriff (Adaption);8x1
    $1CDFD6;Faktor zur Korrektur von rlmax bei E_HDR;8x1
    $1CD99C;Faktor für Ladedruckeingriff auf Overboostwert durch KR;8x8
    $1CDFE3;Faktor zur Korrektur von rlmax bei hoher Motoröltemperatur;4x1
    $1CDFE8;Maximaler Druck prist_w für Berücksichtigung E_hdr;1x1
    $1CDFEA;Verzögerungszeit frxta;1x1
    $1CDFEC;Codeword für LDRLMX (Ladedruckregelung);1x1
    $1CDFEE;Oeltemperaturschwelle fuer Motorschutz bei Getriebenotlauf;1x1
    $1CDFF0;Maximalwert Umgebungstemperatur;1x1
    $1CDA1C;Faktor für langsamen Ladedruckeingriff auf rlmax durch KR (!);8x8
    $1CDA1C;Faktor für langsamen Ladedruckeingriff auf rlmax durch KR;8x8
    $1CDA9C;Faktor für schnellen LDR-Eingriff(Absenkung) (!);8x8
    $1CDA9C;Faktor für schnellen LDR-Eingriff(Absenkung);8x8
    $1CDB1C;Wichtungsfaktor für langsamen Ladedruckeingriff auf rlmax durch KR (!);8x8
    $1CDB1C;Wichtungsfaktor für langsamen Ladedruckeingriff auf rlmax durch KR;8x8
    $1CDB9C;Kennfeld Maximalfuellung Tans Korrekturfaktor (!);10x12
    $1CDB9C;Kennfeld Maximalfuellung Tans Korrekturfaktor;10x12
    $1CDC8C;Basiswerte Kennfeld Maximalfuellung Tans Korrekturfaktor (!);10x12
    $1CDC8C;Basiswerte Kennfeld Maximalfuellung Tans Korrekturfaktor;10x12
    $1CDD7C;Kennfeld Maximalfuellung Tans Korrekturfaktor bei Dauerklopfen (!);10x12
    $1CDD7C;Kennfeld Maximalfuellung Tans Korrekturfaktor bei Dauerklopfen;10x12
    $1CDE6C;Maximalfuellung LDR bei E_hdr (!);8x1
    $1CDE6C;Maximalfuellung LDR bei E_hdr;8x1
    $1CDE7C;Zeitkonstante für langsame LDR-Absenkung (!);8x1
    $1CDE7C;Zeitkonstante für langsame LDR-Absenkung;8x1
    $1CDEC4;LDR p-Begrenzung bei zu hoher Motortemperatur (!);8x1
    $1CDEC4;LDR p-Begrenzung bei zu hoher Motortemperatur;8x1
    $1CDEDE;Faktor zur Korrektur von rlmax bei hoher Motortemperatur;4x4
    $1CDF00;LDR-Höhenbegrenzung (max. Verdichterdruckverhältnis);8x8
    $1CDF62;Maximalfuellung LDR;16x1
    $1CDFA4;Maximalfuellung LDR bei Dauerklopfen;16x1
    $1CE036;Kennfeld LDR I-Reglerbegrenzung (!);8x16
    $1CE036;Kennfeld LDR I-Reglerbegrenzung;8x16
    $1CE136;KF zur Linearisierung Ladedruck=f(TV);10x16
    $1D10A8;Lambda-Sollwert für HMM;8x8
    $1D113A;Schwelle für Erkennung Überdruck im Kraftstoffrail (HDP2);8x1
    $1D2F8A;Faktor Delta Lambdasoll für Bauteileschutz;12x16
    $1D2F7A;Delta Lambda Bauteilschutz, gangabhängig;8x1
    $1D31E0;Verzögerungszeit Lambdasoll Bauteileschutz f(nmot,dlambts_w);8x6
    $1D325E;Verzögerungszeit Lambdasoll Bauteileschutz f(nmot,rl);8x12
    $1D304A;Lambdasoll für Bauteileschutz (!);12x16
    $1D304A;Lambdasoll für Bauteileschutz;12x16
    $1D310A;KFLBTSLBKO (!);12x16
    $1D310A;KFLBTSLBKO;12x16
    $1D5022;Lambda Fahrerwunsch;6x15
    $1D74D6;Offset für Sollwert Raildruck im Schicht- und Homogenbetrieb;8x8
    $1D75E4;Kennlinie Liefergrad HDP Gradientenbegrenzung prsoll;6x1
    $1D760B;Bewertung Offset für Sollwert Raildruck im Schicht- und Homogenbetrieb;6x1
    $1D761C;KL Tiefpassfilterzeitkonstante prsoll-Filterung;4x1
    $1D7624;Minimalwertbegrenzung Sollwert Raildruck;1x1
    $1D7626;Applikationswert Raildruck Sollwert;1x1
    $1D7628;Soll Hochdruck Initialisierungswert;1x1
    $1D72D6;Sollwert Raildruck in Betriebsart Homogen-Klopfschutz (!);8x8
    $1D72D6;Sollwert Raildruck in Betriebsart Homogen-Klopfschutz;8x8
    $1D7356;Sollwert Raildruck im Homogenmagerbetrieb (!);8x8
    $1D7356;Sollwert Raildruck im Homogenmagerbetrieb;8x8
    $1D73D6;Sollwert Raildruck im Homogenbetrieb (!);8x8
    $1D73D6;Sollwert Raildruck im Homogenbetrieb;8x8
    $1D7456;Sollwert Raildruck bei Katheizen (!);8x8
    $1D7456;Sollwert Raildruck bei Katheizen;8x8
    $1D7556;Sollwert Raildruck im Schichtbetrieb (!);8x8
    $1D7556;Sollwert Raildruck im Schichtbetrieb;8x8
    $1D75F8;Kennlinie Maximalwertbegrenzung Raildruck Sollwert;6x1
    $1D764E;Hubvolumen HDP;1x1
    $1DBE64;Codewort BGVMAX;1x1
    $1DBE68;Codeword: Abschaltung Diagnose Überdrehzahl;1x1
    $1DBE69;Entprellzeit Fehlertyp max.: Überdrehzahl;1x1
    $1DBE6A;Entprellzeit Fehlertyp max.: Überdrehzahl;1x1
    $1DBE6C;Codewort Diagnose ASG;1x1
    $1DBE6D;Codewort Diagnose ASG;1x1
    $1DBE6E;Code word für Status Getriebe bei ASG;1x1
    $1DBE6F;Codewort: Prädiktion Beschleunigungsmoment;1x1
    $1DBE70;Reduktionsmoment Getriebe Füllungpfad Dämpfung (PT2-Glied);1x1
    $1DBE71;Offset Beschleunigungsmoment;1x1
    $1DBE72;minimale Getriebesynchronisationswunschdrehzahl;1x1
    $1DBE73;maximale Getriebesynchronisationswunschdrehzahl;1x1
    $1DBE74;Entprellzeit für irreversible ASG-Abschaltung bei Botschaftsfehler;1x1
    $1DBE75;Entprellzeit Fehler Botschaftzaehlerdifferenz zu hoch;1x1
    $1DBE76;Entprellzeit zur Beruechsichtigung von Rasterversaetzen;1x1
    $1DBE77;Ersatzwert Synchronisationszeit;1x1
    $1DBE78;Maximalzeit für Getriebesynchronisationswunschdrehzahl;1x1
    $1DBE79;Zeitkonstante DT1-Glied;1x1
    $1DBE7A;Offset für Hysterese zur Erkennung ASG Momentenreduktion/erhöhung;1x1
    $1DBE66;Fehlererkennung nmax - Überschreitung;1x1
    $1DBE40;Maximalgeschwindigkeit aus Öltemperatur;5x1
    $1DBE50;Maximalgeschwindigkeit aus Motortemperatur;5x1
    $1DBE5A;Zulässige Änderung von vmaxtom_w pro Rechenschritt nach unten;1x1
    $1DBE5C;Zulässige Änderung von vmaxtom_w pro Rechenschritt nach oben;1x1
    $1DBE5E;Maximal zulässige Geschwindigkeit bei ESP Ausfall;1x1
    $1DBE60;Maximal zulässige Fahrzeuggeschwindigkeit im Normalbetrieb;1x1
    $1DBE62;Maximal zulässige Fahrzeuggeschwindigkeit bei Fehler Motortemperatur;1x1
    $1DBFE0;Maximal zulässiges Kupplungsmoment bei betätigter Bremse;8x1
    $1DBF68;Kennfeld mit dem Wert der Momentenbegrenzung;7x4
    $1DBFAE;Momentenbegrenzung zum Kupplungsschutz;4x4
    $1CD912;Kennfeld ""Bosch 16"";8x1
  10. The Following User Says Thank You to icezero2010 For This Useful Post:
    Brycbenn (29th February, 2020)
  11. #9
    Mar 2017
    Many thanks to you sir!!! Its good to know there are still tuners out there willing to help a newbie!
  12. #10
    May 2018
    paris
    map finish
  13. #11
    Mar 2017
    No
    Unfortunately this does not match my list
