What do you think about this?
B1429 Left-hand Rear Side Airbag Resistance Too High
Hi friends,
Ford Mustang
GR3T-14B321-DE
XC2361A-72F
have tried to clear manually, but got 1 dtc left, and i have no idea how to clear this,
- B1429 PEDESTRIAN IMPACT EVENT STORAGE FULL AND LOCKED
pls anyone help me, i attached the files, read by CG100
Don’t bite off more than you can chew...Don’t bite the hand that feeds you...
alex2019 (24th February, 2020)
Did you clear dtc codes from OCS and calibrate SWS ?
This is good working file.
Same pass
alex2019 (25th February, 2020)
really appreciate your helps m8, thank you ....
try and report 7F000, 80000 to program
pass same
After write file turn on and off ignition minimum five times then clear all the codes.
Sent from my SM-N960U using Tapatalk
