Results 1 to 3 of 3
    Jan 2019
    United Kingdom
    Default BMW DME MSD85 HELP NEEDED
    I am working on a BMW X6 2012 E series with 8HP Gearbox
    I am trying to do a DME Replacement job, original is water damaged and cannot read by tricore ot boot
    Have read cas 3+ eeprom, decrypt isn using working key and enter data into DME
    DME installed into car and diagnostic shows DME internal fault or injectors, Car doesnt fire
    I believe this may be due to a checksum error in the P-Flash as the ISN was changed Manually
    Can anybody have a look at the files for this DME and see if there is a problem for checksum or equivalent
    Thank you
    Aug 2015
    Germany
    post msd85 ori, cas ori and post key psw, we can transfer isn from ecu to cas
    Jan 2019
    United Kingdom
    this is BMW E71, if we do it your way the gearbox wont work cant shift
    into gear as it is 8HP with ews active on egs
    need solution for dme isn write + checksum
