Results 1 to 3 of 3
    EUROPE
    Default Trafic 2016 UPC Flash + DataFlash needed. EMM-T4, 231A03142R
    Hello!
    I'm looking for data from UPC 231A03142R EMM-T4, from Renault Trafic without rain sensor (basic version). I reflash it to new version software, and i have errors rain, light sensor, preassure braking system... before reprog i didn't have it, only start stop fault (DTC926768) and i thinking it is flash problem.
    Please help!
    Dec 2018
    use program DD4ALL. with it, turn off all sensors that are not in the car
    Oct 2010
    I'm waiting to get some components resistors today hopefully I will do it according to the plan above I have Ktag and OBDlink EX and renolink . thank you for the info
    The other option thI'm waiting to get some components resistors today hopefully I will do it according to the plan above I have Ktag and OBDlink EX. thank you for the info
    The other option that I have.
    I find already Vivaro kit ECU+BCM from the same year and the keys I believe this is the minimum I will need .will this would be sufficient to adapted to the vehicule or should absolutely will need the emm T4. Thank yoat I have.
